You should really start with the basics.
Type ping 127.0.0.1 in at the cmd prompt and make sure you get a respsonse before continuing.
If you get a time out then the problem is within the machine's network settings.
As mentioned before.
Have Client for Microsoft Networks and TCP/IP installed.
Make sure the nic shows up in device manager.
Make sure that simple file sharing is disabled.
Once this is done. Assign 192.168.0.10 for one computer. 192.168.0.11 for the next. 255.255.255.0 for both
Hook these two computers together into the hub, making sure you are not connecting to the uplink port.
Make sure the cables are standard cat5 and not a crossover cable.
Load up the game.
Make sure you select LAN under multiplayer options.
Make sure TCP/IP is selected
Depending on the game, one will have to create a game first. Then the second computer will connect.
Load up the game.
