so lets say I order a case that has firewire built in...
narzy
7,006
then you don't have native firewire, you can buy a PCI card that will give you firewire but if you don't that plug in your case is dead. its just a header for the controller and not the controller itself.
rudeguy
47,351
14
61
thx narzy...I was afraid of that...so if I want firewire on the front of my case, I need a new mobo and case right?
amnesiac
15,781
Some PCI firewire cards have headers to connect to the front of the case.
Jmmsbnd007
3,286
You could always mod it in. Real simple if it includes one of those dual firewire port things designed to fit in the output area of a PCI expansion slot.
Zim Hosein
Super Moderator | Elite Member
65,501
408
Originally posted by: Transition
Convert it to a serial port.
SERIAL CONNECTIONS 4 EVER
:Q
rudeguy, what MB and case are your ordering, I'm curious as you don't have a "rig" listed in your sig :)
Eug
24,175
1,815
I just bought a card which has an internal Firewire port. Not a header, but a full port. These cards are easy to find and are cheap too. eg. See here. Notice two ports at the back, and also one internal port on top.
Some cases have an internal port attached to the front connector and you just buy a Firewire cable to connect it.
Other cases have an internal port header and so you either have to make your own cable, or else the case might come with the cable.
