So if subs only need like 10 or 20 watts going through them...
glen
15,995
All this uproar started because I said that all you need for an 18" sub in a car is 20 watts.
I have emailed the audio techs at Adire audio for some real world data.
They have likely measured an 18"( or 15") sub in a car with 20 wats of power and can tell us exactly how loud it is.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: glen
110dB at 20 Hz sounds quieter than 110dB at 200 Hz to the human ear.
Yes, but that is not what I am talking about.
I am talking about how you want your response curve to look on an RTA when you are playing pink noise.
I like how our B & K looks when playing Pink Floyd. :p
EDIT:
Breathe is a good song because it's HARD to do when pounding through your spine at whatever dB as the mic is only reliable up to 157 or so. :D
Efficiency is the key to LOUD levels. 88 dB 1W/1M is not going to get very loud. Realize that even 1000W RMS will bring 118 dB IF (and that's a huge IF) the drivers can handle a kilowatt without going completely republican.
105 dB with 100W is much louder and do able. (125 dB) Most people could not stand this volume unless it was very low frequencies like techno beats. Put them in front of a piezo compression horn and blast them with 6 kHz at 130 dB and even a tough lad will scream like a hyenah with a sex change gone bad, drop his screwdriver and run for the head with pants dripping from the crotch.
Cattlegod
8,687
Originally posted by: Cattlegod
he is full of crap. a 20hz signal at 80db would be hardly even loud enough to hear. you need a LOT of power to put out the low frequencies at a high enough SPL to hear.
my system was putting out 140db at 33 hz with the windows up, and 147db at 33 hz with the windows down. It ended up taking 3rd place in the SPL drag race I entered it in.
You can't hear 80db?
You don't know what you are talking about.
That would be audible in any normal enviroment, and percieved as loud in a sound proof room. Loud car stereo systems are 110db. FOr lsitening, I can't see the need to produce mroe than 110 db.
take a look at this graph.
http://www.eie.fceia.unr.edu.ar/~acustica/comite/abc.gif
in the audio world, the line that is red is called A weighting, it is how your ear actually operates. if something is measured at 80db at 20hz, then it is actually 30dbA under the A weighting scale. and I contest that you would have a VERY hard time picking up a 20hz sound at 80db.
also, check these graphs, the curves on this graph are how your ear acutally responds to audio reception.
http://www.eie.fceia.unr.edu.ar/~acustica/comite/fletcher.gif
MikeMike
45,885
66
Originally posted by: myjaja
LOL @ THIS THREAD!!!
Most amps don't even say the truth about their watts. Like off branded amps. Those amps say it has 1200 watts. That piece of sh!t dosn't have a 1200 watts. It's like 35 watts per channel. Have you ever checked the rms on it? Oh yeah, each sub is different. You can't say all subs need 10 or 20 watts. Even speakers need more than that. Look up more information before posting a stupid thread like this one.
and again, myjaja with useless information, prolly doesnt know what he is talking about, just re stating what he has read in other threads.
i completely agree with Glen on this when buying an amp, the only things that you will really be able to tell is if the Amp has a bad ground loop in it, then you can tell. other than that a $50 100watt amp is equal to a $300 100 watt amp.
However, the only difference between these, will be the stated THD (i think its anything below .5% is unnoticeable, i dont remember, and most amps are like .1 and less. The only other difference will be, does the $50 amp actually put out all 100 watts without clipping (squarewave) or will it not?
other than that, the most important things in a system are:
Source, if your source sucks, your output sucks
wiring location, if you run your RCA's with your PWR, most likely you will get SOME interference, but its not guarenteed
Speakers, if your speakers dont have a good response, then nothing will save you.
JLw7's are liked by many because of their rolly type sound, its not a sudden boom supposedly, but rather a roll.
and Glen emailed adire audio, i like his source ;)
of course, some subs 20 watts wont even get it to move because they are so ineffecient in design that it requires lots of power to move.
someone will correct me if im wrong, but all of the freq. charts are given at 5watts if i am not mistaken.
PurdueRy
13,837
4
Also consider room size, if I have a 14 inch subwoofer....in a movie theater lets say....and the audience is sitting 30 feet back from it...your gonna need to supply quite a bit more power for the sound pressure waves to reach them at an appreciable level.
That said, a lot of car speakers and amps are all about advertising so that some dude can go brag to his friend that he has a 1500 watt amp "feeding" a 15 inch sub...and yes, it would never use that much. But car speakers do have to overcome the noise of the road/engine, which is louder than most of you probably think.
PurdueRy
13,837
4
Hivi(the speaker company that is used for swan speakers) uses 10 watts of power with the current at 1.11 Amps for their charts.
The current is 1.11 A.
MikeMike
45,885
66
most of that however is cancelled out because the Cabin Gain of a car is extremely high.
PurdueRy
13,837
4
Your missing the point, the goal of speakers is to play things as you would hear them in real life for music...and as the mix engineer wants you to hear them in movies.
PurdueRy
13,837
4
Yes, I am just making a "for example" type point. I am a home theater speaker enthusiast/designer. Never done car audio before, so I will admit my knowledge is limited. But the two have a lot in common, so my knowledge of one can apply to the other.
MikeMike
45,885
66
dont get me started on that. i think this stupid dorm room has a room gain of like 50billion on movie bass, i mean my 6.5" speakers are nice, but damn, i didnt think they could put out the amount of bass they do in movies, its like movies are JUST for the low end...
PurdueRy
13,837
4
::points to HK AVR 435 with Room Equalization::
Howard
47,982
11
Most amps don't even say the truth about their watts. Like off branded amps. Those amps say it has 1200 watts. That piece of sh!t dosn't have a 1200 watts. It's like 35 watts per channel. Have you ever checked the rms on it? Oh yeah, each sub is different. You can't say all subs need 10 or 20 watts going throught them. Speakers need more than that. Look up more information before posting a stupid thread like this one.
I am the only person who seems to have posted information, or seems to knwo what teh theil Small parameters even mean.
Thanks for the insult.
Originally posted by: Howard
Nah, glen's saying that you only need low power for a system that "sounds good", apparently. He justifies this by saying that a flat response sounds "harsh", though I didn't see any data he used to back up this claim.
Anyway, the maximum amp power correlates (logarithmically) to the maximum loudness. A 1000W amplifier can net you a 10dB higher maximum SPL than a 100W amplifier can, ignoring power compression.
You got it sort of right.
A flat response is harsh as hell.
Are you saying that goes for all systems with a flat on-axis frequency response?
MikeMike
45,885
66
Points to my Marantz 1120 with an underrated 60x2 at 6 hz, and my Vifa PJ6.5" mids, and my Northcreek D-25 speakers.
in movies i have to have my bass boost on the amp at -8 in order to settle the bass down enough.
PurdueRy
13,837
4
:thumbsup: to Vifa and Marantz
I got an underrated 65 watts x 7 so I hear ya there.
My sub level is at -7 on my amp even with the EQ with these concrete walls
Cattlegod
8,687
I'm actually trying to make a point, not catch one :). My point is this: it requires a lot of power to recreate low end frequencies, a lot, especially when you are at sub 40hz (the thick, rich bass) due to the response of the human ear. there is no 50 watt amp that is going to give you the power level you need in an 12"+ driver that will sound good those low frequencies.
MikeMike
45,885
66
IB IB IB IB IB IB IB IB IB IB IB IB IB
did i say it enough times?
glen
15,995
All system far feild lsitening.
Far field is anything more than a foot, I think.
Car listenign is considered faar feild.
PurdueRy
13,837
4
Trust me I know...Try that same signal with the speaker out of its box....see what happens. I put 40 watts into a 6.5" speaker at 50 hz and you could not hear it as soon as you moved off axis....amazing what a resonant chamber can do.
PurdueRy
13,837
4
I believe near field is usually more like a meter...but who's counting ;)
glen
15,995
If anyone follow the link to the pictures of my car system, they would see it is an IB.
sharkeeper
10,886
A 1000W amp in a car can also serve another purpose. If it's truly designed to put out 1000W RMS continuous and your electrical system is up to par you can use it for a variety of things such as:
Making a pot of coffee
Powering a circular saw to cut up some plywood (but you should have done that BEFORE the storm cut the power dummy!)
Run a vacuum, etc.
How?
Just make a CD of a 60Hz sinewave (or 50Hz for those folks living across the pond) with a track 80 minutes long. Remove your speaker cable and grab an extension cord and lop off the plug. Wire this to your amp and plug in a power strip. Play your 60Hz sinus track and turn the gain up just to the onset of clipping. You may need to turn on your loads FIRST depending on the amp as some amps get unstable with no load.
I joked about this idea back in 1991 and then did it with a HiFonics Colossus Amp bridged (1800W x 1 at 4 ohms) We ran a milwaukee hole hawg (right angle drill) and drilled some holes to run wires through studs and ran a decent sized shop vac to clean up the mess. All on amp power. We tried Techmaster PEB as well but the drill did NOT like that very much and the brushes started sparking real bad so we stopped. Think about that the next time you need an inverter. Remember your mileage may vary and as a matter of fact you can blow your amp and alternator out so you may want to tread lightly at first. :p
Cheers!
Howard
47,982
11
So many speakers (measured in an anechoic chamber) of high repute, then?
glen
15,995
What are you asking?
MikeMike
45,885
66
i couldnt tell ya :D
