Originally posted by: raptor13
I'm a sophomore in mechanical engineering and I want to know why you wouldn't just use the compression or extension of a spring method? It doesn't even matter which you do, they're exactly the same.
Get a spring with a relatively low k value so hanging your mass from it will result in a fairly large extension or compression. Hang a known mass from the spring, measure the deflection as accurately as you can. Take the mass off. Put it back on. Measure again. Do that a few times. Use a different known mass. Do it a few more times. Do it as many times as you want to get a whole crapload of measured k values. They should all be extremely close to the same value if you do it carefully. Average all your k values together to get your final k value which you'll assume to be the real value. Hang your unknown mass, measure deflection, solve. Done. It doesn't get any simpler than that and because distance is so easy to measure, you should end up with remarkably accurate results.
Originally posted by: Sukhoi
Oh, IMHO (I chould be way wrong here) I would avoid springs and other deformable objects. Who knows how much your spring is going to change properties from when you're calibrating it to when you do the test.
Don't listen to this kid! He's only a freshman at my school and hasn't taken his materials class yet. So, like he said he might be, he's wrong.
The reason for that is so long as your spring stretches elastically and isn't stretched beyond it's normal limits, a spring retains its properties almost indefinately. Think about the springs in a car... they compress and extend millions and millions of times throughout their life and they're still good. If you compress and/or extend your spring 50 times, you really think it'll make a difference?
The answer to that last question is no.
