Well, I'm in a senior level physics class, and our final ISU is to find the mass of an unknown object. That easy. We can employ any factors known to physics, including but not limited to Hooke's law, deflection of objects, compression/expansion, ballastic pendulums and such. The thing is, there's a number of ways mass can be solved using physics, but we need the most accurate one available.
Our mark depends on how accurate our value is compared to the real one based on a digital scale. We CANNOT read the value off the system we create, nor can we purchase a system - we have to fabricate it from our own materials. I realize error is based upon systematic and random error, but WHICH system is most accurate?
Our physics teacher has stated a few examples:
[*]Hooke's Law (using period vs mass, or extension vs mass) - Basically a slinky on a piece of plywood with the deflection of the object measured.
[*]Compound system - two spring attached to one central balance - Haven't done this one, don't know how it works.
[*]Cantilever system - measuring the deflection when the object placed at the end of a ruler, persay with the other end flat on a table.
[*]Initeral (sp?) system - same as cantilever, but you measure the deflection sideways (so it swings back and forth)
[*]Ballastic pendulum - A period with 10 oscillations with the mass on it, period is given and mass is solved using a pendulum.
[*]Compression - Not sure, basically mass is put on a spring and deflection is measured how much the spring 'sank' down.
[*]Something about Young's modulus might work too, but I have no idea how that works.
I forgot to state that the unknown mass is within a given range of 100g-2000g.
So there are 5 methods. Which would you recommend is the most precise, or if you know of another system, please mention it.
-Simon
-Simon
