Originally posted by: Xellos2099
Some claim that this card is actually worse than a 8800 gts 320, are they for real or are they just nvidia fanboy?
Originally posted by: NullSubroutine
The 8pin for your mobo (4+4 CPU Pin) is not compatible with 8pin PCI-E that is required for the R600. You will not likely see benchmarks near XT speeds. On the XT if you run 6+6 pin instead of 6+8 pin it wont run at higher clocks (nor would it you access the OC part in the CCC).
In order to get higher clock speeds you would need a new PSU so you have the PCI-E 8 pin(either full 8 pin or the 6+2 pin) some PSU's have. However, depending on your current PSU, some manufacturers are allowing people to send in for free 6+2 pin adapters or modular cables.
Originally posted by: Azn
ATI might have lowered the voltage compared 2900xt. Who knows. Make sure you fan is @ 100% when you test for artifacts.
WRONG!
Use ATITool, RivaTuner, AMD GPU Overclock utility etc with 6+6 pin no problem.
Originally posted by: Oyeve
Originally posted by: Aznguy1872
Originally posted by: spittledip
There's an 8 pin pci express connector on PSUs now? All I have are 2 6 pin connectors![]()
Yeah mine only has the 2 6-pins also. Kind of sucks not having that 8-pin one but its ok. Not too many PSU's have that 8 pin pcie. Only benefit of having it is being able to use overdrive which I don't really care about.
Havent installed it yet, just got it sent to my job and it came today and I am still at work.Question tho. My PSU has an 8 pin PCIE connector, do I need to use the 6 pin PCIE and the 8 pin PCIE? No documentation in package and I havent had time to look for the info.
Well I have both an Evga 8800GTS 320 and, a just arrived HIS 2900 PRO, and in every test I have run so far (3dMarks and a few Game marks @ stock speeds) the 2900 is faster. It is also a LOT louder and runs HOTTER.
It easily runs at 750, 1710 on the first try. Have not yet benchmarked at OC speeds as only got it late yesterday.
E6750 @ 3.4 @1.375V, GA-G33M DSR2, 4GB GSkill F2-6400CL5D @2.0V
Antec Fusion V2 HTPC Case W Antec 430 Watt PS
Video Card powered by Thermaltake W0099RU external 250 Watt (300watt peak) PS with 2 6pin Pcie connectors.
VISTA home premium
I am not so sure about the ATI/AMD drivers for use on a 58" Plasma monitor yet, I was just used to Nvidia's configuration options and perhaps CC Center will be as good.
Only problem I see is I don't like the noise level @ 100% fan speed. At lower than 50% the sound level is acceptable and when gaming noise not much of an issue. It fit easily in this HTPC case.
YMMV, but looks good so far.
WRONG!
True story.
Obviously, if you can get the 8-pin, great, as a little extra power surely is better than not, but only CCC needs the 8-pin connected to OC.
Not necessary because the fan will never be at 100% during games. If you test at 100% fan rotation and get 0 artifacts there is still a chance to get some during play because the fan rarely goes above 45%.
you don't want to run that fan at anything close to 100% for an extended period of time. well, unless you work around jet engines on a daily basis. and you're deaf.Originally posted by: Azn
Why not? Fan is adjustable is it not?
Thanks for the info, Sylvanas.Originally posted by: Sylvanas
Don't think there is any difference in Vcore between the Pro and the XT as some people at XS have had higher results using the Pro Bios than to flashing it with an XT bios- therefore it can be assumed that there is quite a difference in memory timings between the different models and separate vendors. No harm in trying it out though, if anyone is game.
LOL. Just for testing overclocks. Some people don't mind the noise.
QFTOriginally posted by: cmdrdredd
Yeah but then if you have to run 100% fan speed to maintain that overclock, what is the damn point?
To find your max overclock limit.
Don't you test your hardware when you first get it and than back off some for tension? How would you know what would be good for a overclock if you don't know the limits? :roll:
Later on you can also buy a better after market cooler for it to get those overclocks. No?
