Originally posted by: 1EZduzit
I refinished our kitchen table from an older solid oak table back in 1976. I stained it with oak stain and then bought the BEST ureathane marine grade varnish I could get. It had a 20 year guarantee as I recall??
I gave it a coat and let it dry overnight under a couple of heat lamps. I sanded it lightly with 220 grit sandpaper, wiped it off with a tack cloth and varnished it again.
I think I gave it 7 or 8 coats but the finish looked like it was 1/4 inch thick. We still use it as our kitchen table and eat most of our meals off of it. Even after 30 years of use, 3 kids banging on it with silverware, getting wiped down several times a day with a wet rag and usually not dried it still looks pretty good.... though it is getting a little dull. That'd be easy to fix though with one or two more coats of varnish.
http://www.taunton.com/finewoodworking/pages/w00060.asp
interesting that it held up... marine grade varnish usually doesn't do to well on interior surfaces such as tables, normally it's way to soft.
