Originally posted by: bignateyk
Originally posted by: Rapidskies
Umm why not use a bar instead of dumbells for a bench?
because I dont always have a spotter
Originally posted by: ebaycj
Ummm.. left-hand only, dumbbell bench press 70lbs, FTW ?
EDIT: then 75, then 80, then back to normal dumbbell bench (both arms @ once).
hmm.. ive never tried to bench with just one arm.. wouldnt it be really unbalanced?
gah....bench excercises is usually good to have a spotter, unless you're using cables. I learned my lesson the same way you did. Cept it happened to a friend of mine. Landed pretty much on the top of his chest, cept it got a bit of his throat.
Anyways, it might be different because your left arm my take a different posture from your right arm. Does this make sense? Watch yourself when you workout, or have someone tell you if your form is off.
