So how do I get all the water out of Everclear?
shortylickens
80,287
17,082
Pure alcohol evaporates quickly. Thats why its mixed with water.
Yur gonna need a science lab inside a refrigerator.
Or just give up on your nonsense.
zinfamous
111,994
31,558
You just uh, boil it. that's how it works!
collect pure alcohol drops in a suspended watch glass above your boiling apparatus.
zinfamous
111,994
31,558
just the opposite: it actually absorbs free water vapor in the surrounding air. For "critical" applications (lol--they never are), we have to re-aliquot our 100% EtOH supply in the molecular lab because as soon as you open the damn lid, you assume the EtOH is now roughly ~98% and eventually gets down to 95% with repeated opening and closing.
crashtech
10,695
2,294
I've used activated alumina to remove water from distilled solvent, but I don't know if using alumina would be suitable for anything potable or not.
MongGrel
38,466
3,067
121
What's the difference between 'pure ethanol' and '100% denatured alcohol'? I suspect the OP wasn't trying to increase the concentration (toxicity?) of Everclear to drink it.
I'm kind of curious WTF the OP is trying to accomplish myself.
norseamd
13,990
180
Everclear is like 190 proof, so 95% methanol. However, that's not good enough. I want to get the water out of it so it is 199%+ proof. Don't ask the reason. How would one go about that?
Thanks!
By distilling it.
zinfamous
111,994
31,558
OK, I just realized that OP claimed that he wants to "purify" his 95% methanol. ...I seemed to have walked over something very important here.
I have changed my advice. OP: whether or not it's 5%, 20%, 30%, 95% or 100% methanol, it is going to have the same effect on you. I would suggest that you test it out, but then I would get banned for wishing death on a member.
zinfamous
111,994
31,558
Wait, how does this work?
Pure ethanol absorbs every little bit of ambient water that it can find. Simply exposing it to air will suck in any available moisture from the immediate environment, and it happens very quickly.
We tend to keep "100%" in small aliquots (15-40ml) so that it can be regularly replaced and so that it limits exposure time. Either way, you just assume that it is actually somewhere between 95%-98%
Humpy
4,464
596
Technically, it's not wishing death, it's science.
I'll allow it.
norseamd
13,990
180
it absorbs water out of the surrounding atmosphere
My brain still has trouble comprehending it works that fast, even after zinfamous explained it to me. Seems like it should take hours at the very fastest.
WelshBloke
33,600
11,736
Well he might not die.
He might just go blind. Or mad... well madder anyway.
One of the treatments for methanol ingestion is whisky, which is cool.
zinfamous
111,994
31,558
even better: an EtOH IV drip, which is how the ER would handle it.
...okay, well whiskey is probably more pleasant, but I'm not sure if it's as effective. :D
Thump553
12,839
2,625
At home? You can't, and even if you could it would just absorb water vapour from the air.
This. I used to work in a liquor bottling plant. We used to have to test the nominally 200 proof grain alcohol when it came in, it was never 200-usually around 195.
BTW, OP you DON'T want pure alcohol, believe me. I smuggled out a few gallons of pure alcohol, had a wild party at my dorm and only went through part of one gallon. But from hangovers the next day (universally reported as worst-ever, rather be dead) we went through a lot of brain cells. Everclear is more than strong enough-there are a lot of states where it can't be sold.
zinfamous
111,994
31,558
This is why we avoid hiring undergrads in the lab.
