Originally posted by: Drayvn
Well if the X1800 was overclocked over 200mhz more with phase cooling and the 7800 was overclocked to 300mhz on the same. And since the 7800 can overclock 50mhz without changing the cooling well...
Its pretty logical to think that you could overclock this card quite a bit without changing much wouldnt you. And since its on a 90nm core and dual slot cooling i think you could overclock the card probably another 50mhz without having to go for more extreme cooling methods.
Look at the logic behind that; it's not numbers, it's percentages...if you could get ~300 mhz on phase from a 7800, it'd be a 70% overclock compared to the ~36% overclock obtained from the x1800XT from your listed numbers. If it takes LN2 cooling to achieve 36% overclock, it's a fair guess to say it's probably clocked high enough at stock and likely can't scale much higher using standard (air) cooling methods.
I mentioned that about M0RPH because his fanboy bias makes for some rather useless comments...saying something wasn't clocked to its limits because you can LN2 it higher is hardly a logical assumption. Honestly, these exact same overclockers got 6 ghz out of a P4 on LN2, and yet Intel could only release it at 3.8 ghz, and you can't get much more out of a P4 on extreme air anyway. What brings M0RPH to believe that extreme cooling has any correlation to standard working temperatures (as well as yields at such high speeds) is beyond me.
Oh well, 2 more days left till the end of all the speculation anyway.
You got to also consider that the 6800 had a core speed of 400 and for the 7800GTX they only increased it to 430 as standard. Thats not much of a speed hike.
For the X1800XT the supposed (still rumour) speed is 625 from the 540 of the X850XT-PE. If you as you say take it as percentages thats a speed hike of 16% While the speed hike of the 6800 - 7800 is 8%.
Anandtech was able to get on, standard cooling, 500mhz. So the percentage in overclocking would have been. From 430 to 500 it is 16%. But what happens if the 7800 had 16% of a core clock increase as standard? the 7800 core would be 460 and the percentage would be 9% at best. And vice versa.
So if the core clock was 460 it would have room for what... 52%. Thats only a 16% difference.
The difference from 430 to 500 is 70mhz which is about 16%. 16% In terms of the X850 to X1800 is about 90Mhz.
So Percentage wise we can overclock the X1800 less and get more mhz out of it!
All im trying to say is that because nVidia didnt jump their core clock so high resulted in the fact that the core can overclock very easily much higher. And you noticed how easy it was for ppl to oc their card up to 450mhz. And what happened to the 3dMark05 scores when that happened (i know its synthetic but its the easiest to get a general performance mark) the scores jumped a huge margin.
We dont know the score that they have on 3DMark05 for the OCed X1800XT but if the margin has jumped like it has on the 7800GTX with its performance with the dubious sell sheets, it might have a larger impact for a smaller percentage increase in mhz.
So again percentages dont count. Or should i say MIGHT not count. Because of what i said in the last paragraph.
And with the CPU, another place where percentages dont count. You can overclock a 3.8Ghz Intel CPU to 6Ghz and it get amazing performance (if it lasts that long :S) but thats an OC of about 55%
You can OC an AMD 35% and it would be quite a bit better. Thats from 2.8 to 3.8Ghz.
So percentages dont really work because one can do more work in each cycle than the other. Percentages are good at telling how much of an increase there is from the previous iteration of the GPU but not what kind of performance it can have.
So this is pretty much what it boils down to performance.
