- Aug 19, 2012
- 838
- 3
- 81
What smartphone has the best battery life with a normal size battery capacity in your experience?
But the Droid Maxx is older than the current-gen phones so it doesn't count.
The best-lasting phone available on any carrier is the LG G2. LG's got some freaky battery magic going on, it'l significantly outlast a Galaxy S4. Easily, and handily. No contest. LG's Android builds just tend to be better optimized for power savings, maybe because they're using a Snapdragon build, whereas Samsung is using a phone and build originally designed for Exynos, and running it on a Snapdragon in the US.
On Verizon, the Droid RAZR MAXX will get better battery life than the G2, but with less powerful older-generation hardware and by using an insanely large battery. It's a trade-off, but depending on your needs it might be a good one. Assuming you have Verizon. If you don't, well, it's not available through anyone else at all, which is why most people kind of ignore it.
Galaxy Note 3, when used right, can have decent battery life, because it has a humongous battery. But it also has a humongous screen, which, when used, causes humongous power drain.
