Smart people- Help me figure out if my TV will fit up stairs!
Nutdotnet
7,721
TV- 50" Widescreen TV.
46" Wide
49" High
24" Deep
And I figure about another inch or so of padding. If nowhere else at least on the screen.
Moving it into a townhome. It will fit through the door without issues.
The tough part-
The living room is upstairs. The stairs go up 7 or 8 steps, then there is a landing (dimensions to follow), after the landing the stairs take a 90 degree turn to the right for another 7 or 8 steps to the 2nd story.
The stairs have 33" (there is a hand-rail which takes up space) of useable width (there is a hand-rail which takes up space). The landing is 36" wide (since there is no handrail) x 39" long.
To sum it up-
Landing- 36"w x 39"l
The TV needs to be able to fit around it.
Sorry if this is a stupid question. I'm not good with envisioning stuff like this, and I need to know if it will fit BEFORE I pay $$ for movers.
THANKS!
Twista
9,646
Thru the window. Man taking a solid fragile tv up stairs that curve :/ gl man!
sry im not smart.
Nutdotnet
7,721
sry im not smart.
Window won't work.....living room is on the 2nd story.
flot
3,197
uhh.. unless the handrail goes floor to ceiling, won't it almost certainly fit, but you'd have to flip it around above the level of the handrail?
Edit: Hmm I guess there are cases where it may not, but... hmm.... I don't think you're going to get a good answer from here. What you need to do is go tape together some cardboard boxes and try it yourself.
NutBucket
27,180
649
Originally posted by: Nutdotnet
Originally posted by: NutBucket
Doesn't sound like a good idea to me. Tipping a RPTV is never a good idea.
Yeah, I know. Never planned on tipping it.
I figure tipping is probably a given if you're getting up those stairs. Who's moving it? People you hired or the guys from the store you got it from?
Nutdotnet
7,721
That's what I am thinking. May be a good idea to make a template.
And you're right, if the movers can lift it high enough it won't be a problem at all. I guess, if anything I can talk to the movers and see what they say.
JHoNNy1OoO
1,496
That's a very good piece of advice. I'd do that since you could find cardboard boxes basically anywhere.
Nutdotnet
7,721
Originally posted by: bunker
How hard it would be to take the handrail off?
I looked at that. It looks like a total of six screws. So taking them off would be easy, as long as they would screw back into the drywall then that would give me another 3 inches of play.
mithrandir2001
6,545
I would say pass. I have the same kind of staircase in my townhouse and it's really difficult to accomodate very large objects. I got a queen mattress up the stairs but I doubt a king would fit without really bending the mattress. A TV has no "elasticity" and the problem is getting around the bend. If you are moving an dumb object like a mattress, you can tip the thing in any direction. You could tilt a 46x49x24 object on its side to get around the landing but I wouldn't want to tip over a projection set like that. Too much risk...and yes, you have a weight issue as well.
I'd get a "regular" TV for now and wait for LCD sets to get cheaper in a few years.
Nutdotnet
7,721
I already HAVE the TV. And I would hate to pass on this place because the TV won't fit. :(
Exact dimensions of the TV.
Unit: 46-1/8" x 50-3/8" x 21-2/3 " (W,H,D)
193 lbs.
It DOES have casters, which does help moving it. Hell, I had a harder time with my old 32" than with the 50"
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
your TV is exactly 2" under the maximum to make the landing turn lying flat. You have a TV that requires 51" of turning room, and your landing has 53". You will have almost exactly 1" clearance from each corner to the wall @ 45 degrees of rotation.
Of course this assumes 90 degree corners on your landing, which is probably not true.
Physics is fun :)
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Agreed on the king size mattress. TV is much shorter than the mattress though.
How hard would it be to just make a box that size? Shouldn't be too difficult - get a bunch of boxes and just tape them together until they're approximately the same size. I'm thinking it would easily fit.
I'm almost positive it would easily fit. I can't even get a queen size boxspring up my stairs, but had no trouble with dressers, etc. That tv sounds smaller than a couch, etc. Did you get a couch up there? Certainly the couch is longer, almost the same height, but also deeper..
