I'm building a new machine in the next month or so and wanted to get some input on how this looks. The machine needs to be housed in a tiny box, and be somewhat portable. If that just won't work, then I'll get a micro atx tiny tower. I won't need sli or dual graphics cards...in fact onboard graphics might work, although I do like a dual monitor setup. Already have the monitors (Dell 2408 and Acer H233H.) Buying everything in the US.
The machine will be used for video & audio editing. Quad core makes quite a difference with video, the audio programs I use don't use 4 cores yet. I might overclock a tiny bit; would like to stick to the stock cooler (and not increase noise).
I'd like to go i7 920 if possible, I realize it'll cost more. Are there other micro atx boards for it that I haven't seen?
Motherboard:
Asus Rampage II Gene LGA 1366 Micro ATX; $235.
http://www.newegg.com/Product/...x?Item=N82E16813131371
Core i7 920; $280
http://www.newegg.com/Product/...x?Item=N82E16819115202
HIS Radeon HD 4850; $130
http://www.newegg.com/Product/...x?Item=N82E16814161244
(people have said the HIS brand uses quieter fans, that's important as it'll be used in a studio and should be somewhat quiet).
Memory:
OCZ XMP 6gb for $125
http://www.newegg.com/Product/...x?Item=N82E16820227388
Hard Drive: Samsung or Seagate; 1TB drive; about $100. Considering Intel SSD.
DVD Burner; either the Samsung SH-S223Q or Sony AD-7241S.
Power Supply: Hoping a 430-500 will be fine (I've used 430s in the past with one hard drive and have been fine). Modular would be great so cable clutter is down. Corsiar 520, 620HX, Seasonic or OCZ?
Case: again, looking for a tiny case.
Thermaltake Lanbox VF1000BWS
http://www.newegg.com/Product/...x?Item=N82E16811133035
or Lanbox light
http://www.newegg.com/Product/...x?Item=N82E16811133044
Apevia X-QPack-BL/420
http://www.newegg.com/Product/...x?Item=N82E16811144110
What do you think? How can I make it better?
Sean
Motherboard:
Core i7 920; $280
Memory:
or Lanbox light
Sean
