Cerb
If RadeonPro's is the same as others (SMAA injector and SweetFX), that's part why I don't like it as well: it doesn't do enough about jaggies and crawlies. The driver FXAA, w/ no settings but on or off, does blur overly much, though.I use both, as per my rig. Radeon Pro's SMAA is very very good, near 4x MSAA quality but without performance hit. Minimal blurring, and this is the key difference.
When all else fails, it does, but at least it works. Some deferred rendering DX9 games will work with that, or in some cases, that's the only safe way to not get a false positive as being a cheat user, for games that otherwise support no AA (which also makes SweetFX a no-go). If FXAA tool can work, it has options.NV's control panel FXAA blurs the hell out of the games i've tested.
The best, in either case, is if the game has it integrated. Then it not only doesn't blur too much in FXAA's case, or still have crawlies, in SMAA's case, but also doesn't blur text, nor HUD elements that are supposed to be crisp, which is an equal problem when injecting either.
