I've been struggling with this issue for some time on a Windows 7 Home Premium machine on a gigabit network. Running a typical speed test (e.g., speedtest.net) shows decent upload bandwidth of around 5 Mbps (600+ kB/s). However, transfers and connections from the server to remote locations through the gateway are significantly slower than this and fluctuate between 15 and 40 kB/s for download speeds at the remote end. I have found this to be the case for downloading from my FTP server, as well as connecting to my security camera software's web server for viewing and downloading clips. Changing ports makes no discernible difference, nor does disabling the antivirus, and Window firewall is turned off in lieu of the router firewall. I'm running a Netgear R7000 router with no QoS, and the ISP has confirmed that they in no way have any traffic shaping/QoS enabled for the connection, which suggests that it's likely a local issue for remote downloads. I'm connecting with a static IP that is passed directly to the router. One other noteworthy item - uploading from a remote location to the server is fast - it's just sourcing from the server that's slow remotely.
Can anyone offer any suggestions for where to start digging on this issue? Ultimately, I'm not sure if it's a networking issue or a Windows issue as I only have the 1 server to test with, but any thoughts would be greatly appreciated. Also note that I'm just a weekend warrior when it comes to this stuff, so my apologies in advance if I end up missing anything obvious.
