Question Slow cpu, low benchmark results. i7 12700
hlexe
31
41
Actually i was thinking my ssd was defective. Probably it still is. But after doing some benchmarks, i saw that cpu is having low scores. İ did benchmarks when i bought this cpu more than year ago and the scores were okey, good scores. But Now after more than 1 year, i am getting low benchmarks scores. İ am posting benchmark results and cpu settings. As you can see it is much slower than same cpu's benchmarked with inter extreme tuning utility. İ checked power limits, everything is ok. İ was using without a problem since now anyway. Don't know what is causing this. The multicore score is especially low. Can cpu get damaged somehow?
Markfw
May 16, 2002
27,388
16,230
There is definitely something wrong hardware wise. 8 regular cores and 4 e-cores = 20. With e-cores off it would be 8/16, not 6/12. CPU or motherboard has a problem. Reload bios ??? I don't mean set to default, I mean flash to the latest.
gdansk
4,722
7,997
The 12700 is supposed to be 8P+4E. CB2024 results are inline with 6P cores, XTU reports 6P cores.
What does it show for core count in BIOS?
Markfw
May 16, 2002
27,388
16,230
Also, I saw 2.12 ghz in one of those slides. Should only be that low if over temp and throttling.
gdansk
4,722
7,997
No, that's normal for Cinebench. It reports that chip as 2.12GHz - the base frequency for a 65W 12700.
hlexe
31
41
Thank you. İ never took core counts into consideration. That was the problem obviosly. İ searched and found solution. Someone on reddit: it was just a windows setting, Unchecked that box and my cpu is back to 8+4 cores. Thank you. İ put those screenshot expecting someone see what i don't see. Thanks
gdansk
4,722
7,997
In the off chance the Anandtech forums outlast that reddit URL:
I unchecked the checkbox "number of processors" in:msconfig --> boot --> advanced options
hlexe
31
41
The problem is i never clicked that box. İt was all windows fault at the end
