slow booting problem
AMD USER
When ever i start my pc it stays on this screen for at least 17-20 minutes (sometimes even longer) . Please help how can i make it to boot fast with 1-2 minutes.
my pc specs
AMD Ryzen 3 2200G( disable the VEGA 8 onboard graphics)
Asus Ex 320 Gaming motherboard
Gskill RAM 8GB(1 X 8)
Corsair VS 550
Zotac Geforce GTX 1050Ti
BIOS is latest.
my pc specs
Corsair VS 550
BIOS is latest.
Your boot HDD / SSD may have corruption or poor health. Check its health with HD sentinel.
I downloaded HD sentinel , and ran it, this is what i displayed. Is it okay.
50c is too much for a HDD. You should open your PC case side panel to cool you hdd. HDD temps should never cross 42c.
In HD Sentinel, goto Configuration---> Advanced Options---> Health Calculation method.
Set Analyse data field (more strict, recommended for servers)-select this to check health more accurately.
Also run Short Self Test, It will take approx 2 minutes.
What are your CPU temps ? Download AIDA64 and do some CPU+memory stress test to rule out any possible hardware problems.
Yeah , the higher temp of HDD is caused due to it is placement in the cabinet it seems, as antec p7 cabinet is designed in sauch a way that HDD is kept sperately undeneath the motherboard in a separate room.
I applied the settings which you recommended and this is what is displayed after that
I ran the short self test and here are the result.
Your HDD seems fine to me. How are your cpu temps ? Try AiDA64
I don't know but i posted the same question here.
https://forums.tomshardware.com/threads/slow-booting-problem.3472068/
According to the solution in that forum, ny hdd is dying it seems.
Crystal disk info values might not be accurate. So i recommended you HD sentinel. Last thing you can do is try Surface test in read mode and check how many yellow or red blocks it gets. I would also suggest you to backup your most important data to any other HDD or USB drive before running surface test.
Could be dying HDD, could be a hang due to some sort of hardware device initialization failure / timeout, do you have any other SATA devices in the PC? Some that only show up some times?
20 minutes to boot into windows?! Something must be seriously wrong. Does it take the same time to reboot into safe mode? How fast will it boot a linux flavour from a usb key? I would be tempted to check all the cables and reseat the memory and graphics card.
No i am using only a single 1 TB HDD but long before i inserted a internal hard disk (which i converted into a external harddisk by using adapter - SATA to USB 2.0 ) through usb.
here is the Surface test. It ran for some 2 hour
Also my PC runs straight for like 10-12 hours a day without a break unless there is pwoer disruption , may that might be the casue, i dunno just guessing
I have no doubt that your HDD is fine. That one dark green block is normal. I want to know exactly where your pc takes too much time. Is it during post or during OS loading ?
I suspect problem with bootx64.efi (windows bootloader). You can use easy BCD to fix it.
Bootloader is a app which loads OS.
Are you using AHCI or IDE for OS HDD ? UEFI or legacy booting ?
In the beginning Asus logo would displayed where the F2 / DEL button would be asked to press to enter bios settings, after that this screen (below attached image ) would appear for a quite long time.
after this my Windows would appear with my username, which takes 15 secs to enter desktop.
Please englightment me the process on how to do it.
UEFI
This is my HDD https://www.amazon.in/Seagate-BarraCuda-ST1000DM010-Desktop-Latest/dp/B01LNJBA2I
Seagate New BarraCuda ST1000DM010 1TB
i am not sure i just compared the model number from my system information
But i not sure whether it is AHCI or IDE
UEFI
View attachment 5314View attachment 5315
AHCI and IDE are modes which you can change in BIOS.
That animation under asus logo freezes or continuously spins till os is loaded ?
You can try reinstalling Windows again, as it will replace your bootloader with stock one and can fix slow booting in your case.
I think it is AHCI modes as in device manger i found this.
I have never seen it during the entire time but I am quite sure that this cirle (encircled with red marker) spins the whole time.
But i might have to install at least 19-20 software , so i am quite reluctant to do it, also i don't have the ISO file.
yeah the spin continues even when the windows background appears (welcome) with my username in the middle of the sceen is diplayed.
Do you have a NAS? Any shared/mapped drives on this system? Is it wired or wireless, your network connection?
No but once i connected my laptop with my pc for file transfer through lan cable, but i think it might have switched off file sharing after the transfer was completed , but i will check again. my laptop is windows 7 and my pc is windows 10.
Also my motherboard deosn not have a WIFI card so i used external usb for accessing wfi my it would have picked up some devices.
i have no idea what is that "magnolia" is and how it came there but the second one network infrastructure is my modem.
The cause of delayed boots as suggested above often is a problem with windows recognition of connected devices which have been offered for enumeration by the BIOS and which may occur even though the drives/peripherals test well otherwise. The anomaly results because the SMART tests proceed from an operating drive whereas the delay proceeds from a difficulty windows has in recognizing and operating the drive. (Speculation on my part). A dying drive might well exhibit such a problem.
Anyway, I suggest there are just two options now, reinstall windows ( off load all personal data as the disk will be wiped) and try another drive. SSds are very cheap now, perhaps take this as a time to upgrade anyway?
I will try getting a new SSD.
