DantheMan2000
what fan do you use with the SLK-900-U and what cfm does it put out/noise?
it doesn't have a fan... it's only a heatsink...
you have to buy a separate fan..
thats why i am asking what fan do you use... plz read the whole sentence next time 😛
Originally posted by: Lyfer
YS-tech 66CFM 40DBA 92MM is a good option.
Originally posted by: gramboh
92mm Panaflo L1A, ~43cfm at ~27db. I'm running it at 12v full speed and it's pretty quiet, nowhere near silent but I am oc'ing right now and haven't got my second case fan in yet so I don't want CPU to get too hot. So far reporting 26C idle and 40C under load on P4 2.6C @ 3.25 (default voltage)
Originally posted by: shady06
i use a smart fan II @ max rpm
Originally posted by: AkumaX
ooo yeeea check that bad boy out
