I bought the following system recently:
Asus P5K Mobo
Intel Core 2 Duo e6750 @ 2.66
OCZ Reaper 2.0GB
Nviida 8800GT 512mb
Sonata III case
250gb HD
I'm currently in the process of overclocking my CPU. I have it running at 3.0ghz (375 x 8), but my problem lies with the likes of speedstep, tm2, etc. I used some quick OCing guides to overclock, and obviously it's best to disable power saving options in the bios. So I disabled C1E, TM2 and speedstep, i save my configurations and restart, and then when I restart and go back into the bios, I see that all the options are enabled. I can't seem to find the reason for this, any help would be appreciated.
Also, I can't seem to find the option for FSB
RAM ratio.
Asus P5K Mobo
OCZ Reaper 2.0GB
Nviida 8800GT 512mb
Sonata III case
250gb HD
