SLI Warning as an upgrade path
Originally posted by: 302efi
Originally posted by: hans030390
this should not prove anything about SLI other than, "make sure boths cards use the same bios" WHICH you can download bios from many places, and there are programs that will flash them for you (or at least with my leadtek)
But if you flash the card(s) bios you kill your warranty :roll:
"hmm..should I TRY to make my SLI setup work by flashing the bios's and maybe kill the cards ?..."
"...or should I keep my card's warrantys and and live with no improvment by going to SLI ?"
Since both cards bios's needs to match, then when doesnt card makers allow end users to flash the bios's ?..OXYMORON !!
I agree. Part of the SLI logo requirements should be BIOS flashing utilites provided that the cards are from the same manufacturer.
