- Sep 12, 2012
- 11,562
- 1,742
- 126
Another reason why SkyrimSE is much better than vanilla. The capacity to run so many more mods with little tweaking. It's amazing.
All I did was I...
1) Downloaded the mods I wanted.
2) Cleaned my main files via SSEDIT.
3) Used LOOT to see if there were any conflicting mods.
4) Cleaned those mods
5) Used WyreBash to sort out which mods that had a red number next to it. (Not Necessary)
6) Fixed FrostFall, Campfire, and Wearable Lantern with this fix. https://www.dracotorre.com/blog/frostfall-se-skse64/
7) Sorted my load order via LOOT
8) Ran game.
PS--> Download SKSE64 before you do anything.
The game has been running amazing well. I have all graphics on super high. Shadows are on high, not ultra. I'm getting a constant 60FPS. Looks great.
PSS--> Don't let the game check for updates via Steam. Check off the option "Only Check the Game for Updates When Running." Then when you play the game, you'll need to go into airplane mode. You need to do this because when Creation Club gets updated it messes with SKSE64. I've read that it happens often. Creation Club is junk. You don't want it.
All I did was I...
8) Ran game.
