hahahah 🙂Originally posted by: gopunk
since you're staying in the same spot, no work
Originally posted by: Moralpanic
Crunches are fine... sit ups start working the thighs once you get to a certain point, so really not use in doing them.. also it's harder on the back.
Originally posted by: Sluggo
I see some people at the gym whip through them, and I wonder if they are getting the benefit.
I like to hold the crunch at the top of the motion for a second or two, doing ot that way, you cant do nearly as many. You fgeel the burn pretty quick.
Originally posted by: EvilYoda
They definitely work, yeah, and a lot depends on technique...if possible, do inclined sit-ups...those are fun 🙂
Originally posted by: acidvoodoo
whats the diff between a crunch and a sit up
Originally posted by: PoPPeR
I recall reading that crunches/situps were like the worlds biggest lie, but I also recall reading that they worked if done properly. Anyone want to fill me in? If they only work if done "correctly", what defines the correct method?
SnapIT:Originally posted by: SnapIT
A crunch is a situp where you don't flex your hips, you only lift your torso...
Try this... lie on your back on the floor with your lower legs on a table (without someone holding your feet) in 90 degrees angle at both the knee and the hip, now lift your torso as high as you can, that's a crunch...
Originally posted by: astroview
So what will give you a 6 pack then Spamela?
