drunkgamer
Hi guys,
Happy Thanksgiving...
Many thanks for the previous info on low voltage cabling! So I was about to get ready to start getting things going when I ran into a site called Smarthome. I was browsing around and started to think about using a small rack in my closet instead of the in-wall Leviton I had bought.
I don't mind not having things inside of a wall, and would rather have a shelf or two to put the router, modem, etc. on that I can see if needed rather than inside a closed panel.
Also, I could have a more robust patch panel if I go that route...
So are there any popular rack mount solutions for a home? In other words not super expensive but are still quality products.
I found a Middle Atlantic solution:
Slim 5 Series 19" Equipment Racks
http://www.middleatlantic.com/enclosure/knock/slim5.htm
~$235 for a 36" one so not super expensive but not cheap. Would still need a couple shelves, etc. Could add wood panels on the sides I guess.
http://www.smarthome.com/8741S521/Slim-5-Rack-21-high-40-5-Inches/p.aspx
I'm thinking about a 24" or 36" option. I'd just have an electrician put a new outlet behind where the rack would go instead of any integrated strip...and would just use a TrippLite or similar for the items.
Any other residential rack solutions for home...and on a home budget?
Thanks
Thanks
