simple network help.
Spamdini
354
so im getting a new computer sometime this week. i already have one computer with a cable connection. what i want is to have both computers on the same connection, its very fast so i dunno if that makes a diff, but i want to also be able to play lan games of say cs between both computers, and i think i want them to both have seperate ips. if all this is possible please lay down your expertise and i shall be very grateful.
thanks in advance
ps please list all the parts i need including cables and stuff.
JackMDS
29,563
432
Link to: AnandTech - FAQ. Basic Options for Internet Connection Sharing
Link to: AnandTech - FAQ. Hubs, routers, switches, DSL, LANs, WANs...?
Link to: AnandTech - FAQ. What do I need for wireless Networking?
Ignore the prices in the links above. The same or similar hardware can be found for 60%-90% less.
Log to this page it has a lot of links to instructions to Windows Network Setting and Sharing.
Link: Installing & Sharing
Link to: Diagram of Broadband Connection with Cable/DSL Router.
Link to: Basic Protection for Broadband Internet Installation.
:sun:
Spamdini
354
i have an aolder pc now but if i get a MSI K8N Neo 2 platinum it has the giagbit lan on it means i dont need a NIC card obviously right?
Spamdini
354
ok, so after reading those artilves im still not that clear. do i need a swicth or a router or both?
amdskip
22,530
13
You need a simple 4 port router. You can basically look at a router as a smart switch.
JackMDS
29,563
432
The Cable/DSL Router is a combo unit.
It provides Routing to share the Internet, and a Switch to connect four computers.
If you use a Cable/DSL Router you need.
1. One NIC in each computer.
2. Cat5e cable for each computer to connect the NIC to the Router's Switch.
3. External Ehterent Cable Modem with a CAT5e Cable to connect to the Router's WAN Port.
:sun:
