Sigh. With FX-60 the end of S939 has come!
Originally posted by: t3h l337 n3wb
I think I'll just skip M2. I just built a computer last summer with a 3200+. I'll just upgrade to an X2 later, then wait til the next platform comes out with DDR3 support.
Yep. No way I'm buing a new proc AND mobo AND memory. I can upgrade to an X2 and double my ram for a fraction of the $$. That should hold me until at least early '07.
The A64 is not starved for mem bandwidth even now with current ddr mem due to it's low latency mem controller, so any improvement ddr2 might bring will be marginal at best, especially with it's higher latency. S939 is the top socket right now, and will remain near the top until either Intel releases a cpu that's a lot better than the A64, or AMD eventually produces 3.5+ ghz chips for the AM2 socket. I'll probably keep my S939 for at least another year, and possibly upgrade to a dual core A64 when the prices are lower.
Wow, prices for DDR2 memory are already rising. Quite a bit in the past 3-5 days I guess. For a while I was buying retail 1GB kit Cosair VS DDR2 533 for $60 shipped. It's back up to $70.50 now, hasn't been that high for a month.
lolololololol
i swear you guys make me laugh. first the guy posts some link to 300 $/GB ram, which BTW JACKASS is 1 ghz RAM. ITS PC8000. I dont see why the hell you would buy that since your mobo, and your CPU would clearly become the bottleneck.
then the people that overclock their ram and mobo fsb over the 200 mhz mark, loosening their timings to get better performance... your doing that, and at the same time your telling me that 333 mhz wont make a difference? ok, so lets see, if I could overclock my ram/cpu/bus to 333 mhz, without frying my cpu or chipset, and have my ram timings at 4-2-2-8 (ocz ddr2 667mhz platinum kit), I WOULDN'T SEE ANY PERFORMANCE INCREASE???
Ok guys, well see. Actually youll see.
Originally posted by: JAG87
lolololololol
He said $300/gig for e-penis ram vs $150/gig for e-penis ram, not standard value stuff. The people that are overclocking their ram are doing so with overclocking their CPU which is giving them the real performance gain.
Yeah, we'll see. Calling people jackasses etc. before we see what's relevant to processors that aren't out yet seems pretty foolish.
Originally posted by: n7
It won't.
Sure, performance will be improved, but it will be at high prices, with little motherboard selection.
After AM2 has matured, i'll get more interested.
precisely
im calling the guy jackass, cause hes dissing ddr2 for costing too much, yet hes looking at PC8000 ram... how stupid can you get. really?
the ram i chose is not starndard value stuff, its the best ram you can buy. some people like corsair, or crucial whatever, but i only pick the creme of these manufacturers. but buying 1 ghz ram is just plain stupid because its going to receive data at 667 mhz anyways.
yea yea yea! thas strait doaw... aneyway ima try and cum up wit some rent u know..? i know.. then ima get one.. but i gots to get my tercel sum rims dudes. pyce.. holla at ur amds Foo me.. right now wit some dota and shyt
It won't.
Agree completely.
QFT, exactly my thoughts. I'm thinking in 1.5-2 years I'll jump on the band wagon.
I'm not complaining about DDR2 costs at all. In fact it's even better for the value segment at $60/gb, I'm just saying the 'flagship' standard has risen very high. I'm sure there are people who will buy that RAM, and then come here and complain about how it didn't improve performance according to its cost. Which is what I'm complaing about.
Oh by the way Mr. jackass it's going to transmit data at 333MHz because it's still a form of DDR, and that's if, and only if I leave the LDT at 333 and mem ratio at 1:1. What I'll likely buy for AM2 or something similar/better by the time that happens.
It won't.
Agree completely.
me2, rumors also has it that the shift for DDR-2 will be rather short and probably with 18 months after the launch of AM2 they will shift to DDR-3.
Let me start a rumor.
The next socket after AM2 will support, through the new Rambus memory controller AMD has licensed, DDR2, DDR3, XDR, and a few other memory formats, and will only need the physical connects on the motherboards to be different. Same as when Intel's old chipsets used to support SDR, DDR, and RDR.
Lets look at history. Going from 266 to 333mhz fsb on Athlon xp, no difference. Going from 333 to 400mhz fsb on athlon xp, no difference. Going from 400 to 533mhz fsb on P4, no difference. Going from 533 to 800mhz fsb on p4, some difference. Going from 800 to 1066mhz fsb on p4, no difference. Going from 600HTT to 800HTT on Athlon 64, no difference. Going from 800HTT to 1000HTT on Athlon 64, no difference.
Going from DDR to DDR2 offered no performance improvement. Going from single to dual channel on athlon 64 offered no performance improvement.
Going from socket 754/940 to 939 offered no tangible improvement on a clock for clock basis.
Based on history, there is absolutely no way we could question your logic that 333fsb(the athlon 64 has no fsb) and ddr2 667 will improve performance of the Athlon 64 by a large margin.
WTF! Most of those had large increases, usually around 5% - 10% increase. A 2.4ghz 800fsb P4 can often outperform a 3.06ghz 533fsb. The jump to 1066mhz was a smaller performance increase, from 1% to 3%. The HTT was about a 1% to 2% increase.
Dual channel was around 5% to 10%.
Each increase may be small on their own, but they add up fast, especially given that the cpu industry only doubles in performance about every 2 years.
DDR2 will ultimately be a 5% to 10% increase too, though overclocked DDR will close or eliminate that gap. However, DDR2 will be cheaper, and won't have crazy limitations like dropping to 333mhz because you used too many sticks. The industry did not decide for DDR to last this long and AMD continually has to tweak their memory controller because they're hitting the limits of the DDR spec. For most users it's not a big deal, but high end users, such as servers, workstations, and gamers who spend thousands of dollars on FX cpus, are being hit by it, and that's the reason why the Opterons and the FX cpus get the tweaks first before the rest of the line.
That said, if I had a 939 system, I wouldn't be upgrading to AM2. However, I'm still on socket A, and AM2 presents a nice way for me to ditch all my legacy hardware. If I was on socket 754.... there's a bit more leeway since the rest of the hardware isn't as out of date a 939 upgrade may be reasonable. In my case, I'm going to have to be buying new everything anyhow no matter what platform I go to, so I may as well get the most up to date. (though 65nm AM2 chips could be a good reason to go AM2)
It won't.
Agree completely.
Oh man.. That's what we S754 owners though until AMD completely left us out in the cold, ending the amd64s to be relegated to budget duty...
I'm still slightly interested to see what Intel's next series can do before I decide anything. Currently I'm pretty happy with my P4 running 3.2 on an Asus P4P800. Yes it's kinda old and can't really compare to a new AMD64 setup, but it's find for now. When I compare Intel's new stuff to AMD's new stuff I will decide.
It won't.
Agree completely.
What's to complain about? You're really only missing out on dual core, Venice processors eventually hit S754 and most people who care overclock anyway. Intel similarly ditched their S478 platform, and Socket A suffered a much worse ditching, though those two sockets had a longer run. (423 is probably the ultimate in ditching though)
I don't see them on pricewatch.
Where are they? I told some people about this processor and they want to order them NOW.
WTF was that in any language recognizable to humans?
I remember jost a little over 1 year ago having similar arguments over S754 and S939.
Some said go with S939 becasue it is more future proof. While S754 proponents said you get more speed for the money, and future proofing is worthless. When you decide to upgrade the CPU, a MB will almost always be required anyways.
Well I bought a 3000+ Winnie S939, but it was AGP. Now when prices fall on the X2's, I have plenty of room to upgrade there, but I still would need a PCI-e MB if I wanted to upgrade my VC (which I most defintiely will).
I seems that no matter what we do, we will always wish we had waited just a another month or two for the latest technology. Of course if we actually did that, we would never end purchasing anything.
So IMO if you are ready to build now, I see no season to wait on AM2. You will get more "bang for buck" out of a S939 system. Then when you need something faster, something else will have changed that requires you to buy all new components anyways.
This is a VERY simple concept.
Buy the BEST MB, CPU, and Memory you can afford at the time.
You can't futureproof and you can't predict the future.
With the speed of advances in Computers, forget about futureproofing. Buy the best u can afford at that time, and avoid catching the upgrade bug everytime something new comes out.
I'd still say it's wise not to make big upgrades right before the next big thing comes out. For instance, anyone buying a high end laptop this month instead of waiting until the new models next month is very foolish. I could more easily recommend a cheap laptop right now though, as at least then you aren't out as much.
In the case of AM2, I think it just comes down to cheaper memory prices with DDR2.
DDR2 is only cheaper to those that would actually need to purchase new RAM anyways.
Anyone that already has 2GB DDR (like myself) gets screwed.
True, but AM2 isn't going to offer much higher performance anyhow. Currently you can overclock to 3ghz on 939 with the right cpu, it's unlikely that AM2 will go beyond 3.2ghz or 3.4ghz.
Originally posted by: Ilmater
People, this is ridiculous. Depending on how often you upgrade, you'll have to buy a new board anyway. Even if you only wait 1 1/2 years, you know the RAM/FSB speed will increase beyond what your board can handle, and unless you want to cripple your brand new processor, you're going to buy a new motherboard. For YEARS I've said that I'm buying things and I want to keep my motherboard and just upgrade my processor, but it never happens and it never will. The performance increases usually aren't there.
QFT!! :thumbsup:
