I have mine set up a bit differently for my 1000AMG... I have the two fans in front blowing in. Then I have the side blowing in on the video card. I use the XP-120, so it sits pretty close to the glass, and is spread out over a large area. I have the lower rear fan blowing in, and the upper rear fan blowing out. I then put a piece of paper (folded) between the two rear fans and over the top side of the XP-120 to 'duct' the air. That way the lower rear fan and side fan blow air into the case, and sort of at the CPU hs/fan. Using this method, I went from 30C to 28C for my CPU temp and the case temp stayed the same at 30C idle. so the CPU is actually cooler than the case temp, and with VERY LITTLE modifications (a piece of folded paper, actually an old bill that I had laying around.)
