Sick of Restricted Shower Heads
BoomerD
66,511
14,898
I've drilled out every showerhead I've owned for the past 30 years.
It works better with some than with others, and I've ruined a few, so YMMV.
Darwin333
19,946
2,330
Depending on where you are and what you read, a low flow head can save roughly $20 or more per person per year. So for a family of four, that's about $80 a year.
$80 whole dollars a year? Screw that, I'll happily spend that to have nice pressure in my shower.
13,919
You need a German shower head, they have an 11th hole. There's historical reasons behind that which I won't get into, but that extra hole really does help for giving that extra power, and it's German, we all know the German make good stuff.
FelixDeCat
31,144
2,746
Fixed this problem long ago. I actually take shorter showers with the increased flow. It simply takes longer to wash with low flow.
WHAMPOM
7,628
183
I am so sick of the restricted shower heads. I’ve tried so many different ones;
I’ve removed the restrictor, tried drilling out others for better water flow, but still can’t get that strong invigorating spray I so want. I have 80 lbs of water pressure which should be just fine. Does anyone know of a strong shower head, even if it requires some modifications.
Yes, I am aware of the Seinfeld shower head episode.
How is the water flow with the shower head removed? It may be a restriction in the valve or pipes.
