dullard
- May 21, 2001
- 26,187
- 4,853
- 126
Yes, I used married filing jointly in that post.Originally posted by: TheTony
I assume this is married filing jointly? Just curious.
Originally posted by: coomarlin
Originally posted by: Mxylplyx
Measuring your tax burden by the amount of your tax return is a simpleton way of going about it. Your taxes have gone down after getting married, and your tax withholdings likely went down as well if you changed your W-4 status to married. If your that beat up about it, both of you file single and 0, then you can both feel warm and fuzzy come tax time when the government returns your large interest free loan to them.
You don't need to be a sarcastic smartass about it. I never said I wanted some big fata$$ check. I personally wouldn't care as long as I break even.
We just got married in November and after changing my W4 status to married my salary paycheck did not decrease or increase one bit.
My issue was that my federal taxes did not change based on getting married but my state taxes changed quite drastically in my opinion. we went from a $1300 fed return to a $1275 return and that measily $25 difference is probably attributed to a slight increase in earned interest. But our state return went from +200 to -360 which I thought was odd. Sue me..............
You might not get "Beat Up" about taking a $500 state hit but I wasn't expecting it. Especially condsidering we broke even with the fed return. If you read my initial post I said that $500 was not a life changing amount and it will not break my bank. Was just looking for some clues as to why we lost $500 just for getting married.
Originally posted by: Fern
Th usual problem is that workers (husband and wife) redo their W4s to show MFJ.
Since the payroll w/h charts issued by the IRS automatically assume that only ONE spouse works, both people get credited for increased personal exemptions (the other spouse) and both get credit for the full amount of the increased standard deduction. I.e., every deduction is given twice, when you actual file you only get them once.
Fern
I'm going to do a comparision of last years taxes with this years. Like I said though, our incomes haven't changed at all and neither of us changed our withholding. So I expect the ratio of income to withholding to be pretty much the same bewteen 2006 and 2007.
Fern
I'm getting married this year. So I should keep my withholdings at whatever I have now to keep the possible tax hit down? And he should be single withholding 1 or 2 (maybe 2) when he starts working later in the year?
Not huge life changing amounts but annoying none the less.
Last year between me and my girlfriend as an unmarried couple we received about $1500 in fed and state tax returns. ($1300 federal and $200 state).
This year as a married couple filing jointly we will receive $1275 from the feds but we apparently owe the state $360! WTF? Our jobs haven't changed and our income is basically the same. So instead of netting $1500 we will only net about $915
We have a very simple return as we don't have any kids and do not own a home yet. We take a standard deduction and don't itemize.
I always thought getting married helped your taxes?
Fern
Yeah,
If you change your W4 to MFJ your withholding will drop. Best to keep it at "single". He should use "single" too.
There is no "tax hit" when you get married. Again, the problem is that when you switch to MFJ status on your W4, the w/h tables assume that your spouse is unemployed. By doing so, it gives an extra exemption (under the assumption your spouse won't need it) and doubles the amount given as deductions (standard deductions doubles from single>MFJ).
Hope that helps explain better
Fern
Fern
Yeah,
Fern
Thanks for the attempt at explaining things but now I'm just as confused as ever. I was only married 7 weeks in all of 2007.
I filled out the state tax as married and again filled it out as single. As I posted above we lost $478. If we could file single we'd get back $152. But since we have to file Married we owe $326.
How is that not a "tax hit".
We did not take a hit with our federal taxes. We got back roughly the same amount married as we would've if we had filed single. But the state is a totally different story.
-snip-
-snip-
My remarks were directed at the federal implications etc.
Look to your states tax brackets first.
E.G., for the federal baracket (I'm using 06 amounts, can't find my book for this year) the 10% bracket is as follows:
Single: $7,300
MFJ: $14,600
They just double all the brackets for MFJ so there is NO penalty for being married.
Looks like your state doesn't and that's likely the problem. I'll see if I can find info on your state. Looks like they still have a "marriage penalty". The Feds eliminated it several years ago.
Edit: Ouch! Looks like WV only has one tax table for use by Single, HoH and MFJ filers. If that's the case, yes you're getting a "penalty" for being married. You're combined income is therefore going to push you into higher brackets.
Fern
Originally posted by: Starbuck1975
I made this same mistake last year. Both my wife and I changed our withholdings from single to married, so the govt took out less taxes each paycheck...we also jumped a tax bracket last year.
So in our case, we got hit with the marriage penalty big time...2006, we got a modest refund from the government...for 2007, we owe a total of around 7k to state and federal.
We changed our withholdings back to "withhold at the higher single rate" so we don't get hammered again this year.
Originally posted by: Baloo
Jeez, you get married, combining two incomes, your net earnings went up probably close to double, and you think it's a penalty cause you pay a couple hundred dollars more than you did last year, ignoring the fact that the standard deductin last year was higher than this year, so the real difference is less.
Wahhhh! Wahhhhh! Wahhhhh!
