Should we get Anand to review these rooted nooks?
thecoolnessrune
9,673
583
Unless you've had a hardware failure it is literally just not possible to brick the device because it will ALWAYS poll to a bootable SD image first before anything else. So as long as you have a properly made recovery image on your SD you should be able to get it to boot to that even if there's a complete eMMC corruption.
Check this thread. You're not the first to have this issue so first thing is remain calm and second is to follow those instructions exactly and you should be getting up and running again with a bit of effort :)
EDIT: Well dern, 2 posts late.
Sheep
1,275
That XDA link has saved my dumb ass on multiple occasions when screwing around with my own Nook Color and inadvertently formatting the boot partition when trying to root my friend's Nook Color from memory.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
I'll give it a go, but I don't have a lot of faith in my tech abilities as of late =/. I've messed it up a few times already but it's always at least been able to power up. As it stands now it never does a thing... it's like the battery is completely dead or something.
edit: well fuck me runnin... it's booting from SD
MagickMan
7,460
Yep, it takes a lickin' and keeps on tickin'. You can mess them up, but it just about requires physical abuse or modification.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Bah, now I'm stuck in a clockwork mod recovery loop. Trying to restore from backup but it's just booting right back to the recovery screen regardless. This isn't from a bootable sd card either.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
I did. I've given up on clockwork mod as my major problems have come from using this. Google has produced a number of results of people having similar problems as well as hanging and bugs. I'm going to start fresh yet again but avoid that particular manager unless I'm out of options.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Alright I think things are going well enough. I installed an overclockable kernel and have setcpu running. I also figured out how to get SwiftKey running on rooted Nook fw.
s44
9,427
16
Well, not necessarily. The review is of the gimped wifi Tab, and assumes you have to pay $350.
Vivek is right that $350 is too much, although a 10" Transformer isn't the equivalent of a pocketable 7" Tab.
TSDible
1,697
The article also assumes that you pay $250 for the nook which is also too much.
I got mine for $200.
ponyo
19,688
2,811
Same can be said of the Galaxy Tab. I paid $214 including tax for my AT&T one which is far superior to the gimped WiFi Galaxy Tab. :)
poofyhairguy
14,612
318
Pretty amazing to see that the Nook Color has a better screen than the Galaxy Tab (or iPad 2). I figure they used the same screens.
This review would have been more awesome if the Nook Color had a newer version of CM7 (battery life would have gone up) and an overclock.
finbarqs
3,617
yeah... anandtech needs to start review rooted/jailbroken devices. these are basically the norm now for anything and everything!
vshah
19,003
24
att weekend sale, $199 + tax + cancel contract after 30 days.
oh, sweet. I thought you usually had to return the device if canceling within the thirty day period
Sent from my Nexus One using Tapatalk
