Should Intel release a Unlocked Multiplier dual core for Ivy Bridge, Haswell, etc
Should Intel release an unlocked multiplier dual core for Ivy Bridge, Haswell, etc
  • No
  • Yes, for i3 only
  • Yes, for i3 and Pentium
  • Yes, for i3, Pentium and Celeron
zlejedi
303
Intel already tried the waters, and it just showed it wasnt viable.
By ofering shitty overpriced dual core i5 which costed as much as quad core i5 750 which could overclock perfectly fine and with much cheaper i3 which had same features and oc ability.
It' almost like they made self sabotage to have desired test results.
Nemesis 1
11,366
NO way. people want to overclock cheap cpus buy AMD what you want amd gone sooner than later. Intel won't do it . It would hurt them and AMD . Likely killing amd.
Plimogz
678
I can't wrap my head around the question, frankly. "Should"? from whose perspective?
A highly OC'd dually would be (was -- not very long ago) an killer budget chip, and notice how it's gone, now. And given that all projections based on recent performance of their silicon would lead me to believe that such chips would have great OC%, what possible reason does Intel have to release such a dynamite part under, say, 170-190$? And by then you're really pushing into unlocked quad territory. Unless they quicken the rate at which they'll increasingly withhold upper-midrange performance without better competition from AMD, and thus create wider gaps between the i's, I can't see where this dual-core budget-bomb would safely fit.
And unlocking the Celerons and Pentiums? Not unless they're going for AMD's throat clean and simple. That is, if my assumption that struggling AMD is still selling any significant amount of desktop chips at this point... Yeah, I figure that there's a lot of blood in the water for sure, but I doubt that Intel's anywhere near hungry enough to choose to take this one decisive bite.
But oh, how I would beat the crap out of a $75, 100% OC, unlocked haswell celeron. Mmmmmmm.
