jlee
- Sep 12, 2001
- 48,518
- 223
- 106
The problem with circuit breakers is that they're not always reliable and sometimes the wiring in the building is either substandard, or some idiot put a breaker that was too high for the circuit. (20a on a circuit with 14ga wire that isn't knot and tube)Originally posted by: JLee
Originally posted by: Nik
Originally posted by: So
Really simplified answer: Sure, if you don't use more than the number of outlets on the smallest one.
This, but that just means you're basically using a power strip as an expensive and very short extension cord.
Why does the number of outlets used matter? I would think that overall power draw would be more concerning.
Because more outlets gives people an outlet to draw more current which can lead to some shocking results. But yeah, if you've got like 30 5 watt devices, opposed to two 500 watt devices, the 30 5 watt devices SHOULD be less of a hazard, though you've also got to deal with other unforseen issues like a higher likelihood of one of them failing or something like that.
That's what I said, and you're not going to fit 30 devices on two standard power strips.
Do you mean wiring that is knot and tube? That's old stuff, and 14ga is not good for 20 amps regardless.
Originally posted by: CptCrunch
I can tell you that the campus fire department won't like it, and you'll risk tripping the breaker.
I can also tell you these things from experience, since I had my own little server farm with lots of networking equipment, TVs, game systems, plugged into my dorm in college. Anytime anyone wanted to use a microwave (all 3 rooms were occupied by my friends and all shared the same circuit), we had to yell "MICROWAVE" and start turning off TVs and monitors so we didn't trip the circuit breaker.
:laugh:
