Should I use the parking brake when parking in an automatic?
Do it?
  • Yes
  • No
MJinZ
8,192
I've been doing it in this order:
1. Press firmly on brake pedal
2. Engage parking brake
3. Shift to park
4. Release brake pedal
When I start back up:
2. Release parking brake
3. Shift to drive or reverse
My car also locks the doors automatically whenever I shift out of park. I've already had to replace my driver door actuator once at a cost of a few hundred dollars. To save the wear on my locks, I've been shifting into neutral, engaging the parking brake, and letting my foot off the brake when I have to wait in drive-thrus and railroad crossings. Is that bad?
Your order works fine too.
Shifting into neutral is fine too at a stop.
Throckmorton
16,829
If I'm on a hill I do this:
Mash brake pedal
Shift auto trans to neutral
Pull parking brake
Release brake pedal so the parking brake takes the stress (I have rear drums so it's not an instant lock)
Shift the transmission to park
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Mash brake pedal
Pull parking brake
Yup. You and Obamanation got it right.
I do this all the time so it's habit now; I don't even think about it, the muscle memory just does it.
ZV
franksta
1,967
ZV
My daily driver truck and weekend car both have foot operated parking brakes. My wife's car is hand operated. If I happen to drive her car I look quite the fool pressing my left foot against nothing "applying the brake". She even gives me a weird look for my efforts. :awe:
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
I've been in so many different rental cars with different parking brake arrangements that I now subconsciously perform both actions. :awe:
ZV
vshah
19,003
24
i do the same thing if I get into an automatic car after a long time. At about 10-15mph, my left foot will be frantically stabbing the footwell and my right arm waving around in front of the dash
LTC8K6
28,520
1,576
With many cars you can program the auto door locks, so it's possible you can stop them from doing that.
thescreensavers
9,916
Parking brake on an incline for sure. You need to keep it in drive, put the parking brake on THEN put it in Park.
I did it the other way around once in my car and when I took off the parking brake and put the Tranny into D I heard a loud "Ping sound" something not healthy.
So If I ever park on a hill, while holding the brake, put the Parking brake on, and put it into park. When I get back in Hold the brake, take the parking brake off and then put it into drive.
I guess the Pin that slides in got removed with another gear putting tension on it and the gear spun and hit the Pin causing the noise. Any how I wont be parking on hills in Florida any more any how. This was in a parking garage lol.
kornphlake
1,567
9
Next time tell her you're using the "air brakes" :)
zerocool84
36,041
472
Every woman I've seen only uses it on hills. Doesn't matter to me not my car. If I drive their cars though I always put it on cus I drive manual so it's automatic for me to use the brake.
thomsbrain
18,148
I always rest the car on the parking brake in neutral before shifting into park if I'm any kind of grade. On flat ground I just shift into park first and add the brake as a fail-safe.
Sust
600
For those of you who said "yes", what has your experience been like with rotor warp after park brake usage? Furthermore, how hard are you yanking on the park brake handle before you think you've got enough stopping force?
JulesMaximus
74,588
986
I ALWAYS set my parking brake. I've owned this car for 7 years now and almost 90,000 miles and still have the original rear rotors on the car.
Why would the parking brake be any different between a manual transmission car and an automatic in the same make and model anyway? I've never heard of rotors warping due to using the parking brake. Sounds like a ridiculous urban legend to me.
I use as much force as is necessary to set the brake so that it keeps the car from rolling. I've never measured it personally.
Perknose
Forum Director
10,728
147
I confess, I only set it when on an incline. :\
I've seen plenty of people abuse the pawls in their trannys horribly -- not setting the parking brake on an incline, slamming it into Park while still rolling somewhat -- but I personally have never known anyone who had one fail or snap anyway, have you?
jlee
48,518
223
I've never even heard of one breaking - granted I haven't specifically looked for a case, but still. We haven't even broken one in a cruiser yet! :p
LTC8K6
28,520
1,576
With 4 wheel discs, the parking brake often doesn't use the rotors.
Viperoni
11,084
Wearing on the parking pawl is nowhere nearly as important as wear to the motor and tranny mounts. Those also take a toll when you don't use the parking brake when parking.
skyking
22,819
5,983
No trailer and flat ground like my driveway, no. Any grade at all and I lock it down with the PB first as detailed above. I always use it with the trailer.
CraigRT
31,440
Use it.
When you stop using it, the time you go to need/want to use it, it will be seized.
At least here in Canada, that part is critical for a vehicle safety... Using it makes sure it always works.
