Originally posted by: Neavo
there are those of us that say go for it, there are those of us that say not to go for the X2.
im one that says dont. you dont need it at this stage, waith 18 months when thats all thats made. Right at the moment, there arent many programs written for hte dual core, not many softwares written in that bit. kinda like the Athlon 64, its a 64 bit chip, most software is 32 bit. thats the problem we had with windows 3.1 going to 98. all programs back then had 16 bit interfaces, so when the 32 bit os came out, the cpu had extra work to do converting 16 bit into 32 bit. same thing with the x2. its a great chip yea, but it doesnt do alot more for ya, go with a AMD 64 3200 or higher, but use a 32 bit OS for now. a good video card (256-512MG) should take alot of work off your cpu, not to mention plenty of ram. so thats where i stand.
if you work for the I pull stuff out of my ass department then yeah you are right. Fortunately, you aren't. Windows 95/98 could run 16bit apps without any of the extra work you mentioned because 95/98 was still basically a UI on top of DOS with better 32bit support.
reading the rest of your post I can see you don't seem to know much about computers, OS, and the basic architecture of PCs in general. CPUs starting with the 386 (I believe starting with that CPU) were 32 bit chips so I have no idea where you got the idea that CPUs needed to convert. I'm guessing you thought that since athlon 64 is a 64bit chip then all CPUs are converting to 32bit because of the OS, I don't know what nonsense you were thinking of but you were coughing up not just the wrong tree but a whole forest.
