Should CPU/Sockets be colour coded?
And with that just confirms that what you said was right... You want to see only soldered crap?
You know that on soldered chips if the MoBo dies, everything dies too? And that happens a lot on Celerons N...
You seem to create your own reality of what's written.
You understimate Africa and Latam really heavily... The world is not USA BTW
Plenty of Internet in Latam countries and Africa. If people got a PC, they are very likely to have internet access as well one way or the other. You be surprised how far ahead some African countries for example is on stuff like mobile payments.
I don't. Internet access in parts of Africa is terrible, but it's there. That's obviously not the point though, which is the absurdity of your argument that people might have no internet access to see what is compatible, but also be too lazy to read the manual before doing a CPU upgrade.
back on topic...
Instead of color-coding, make the sockets/chips different shapes:
square
rectangle
parallelogram
trapezoid
They don't have to have extreme aspect ratios or anything, just enough to make it obvious for the majority of idiots.
back on topic...
square
rectangle
parallelogram
trapezoid
They already are different shapes, you physically can't insert an LGA1150 chip into an LGA1151 socket since the tabs are different, just like DDR DIMMs of different generations are the same size but keyed differently.
If you can't be bothered to read something, and then when you try to put it in it obviously doesn't fit but you try to force it anyway, too bad for you.
If someone is trying to force a cpu in to a socket when the keying doesn't match, do you really think a color will deter them?
If they can't figure out cpu compatibility or inserting a cpu, would you really think they even got the right memory, power supply, or even case?
Same person who can't figure this out is probably also putting regular petrol in a diesel carD:
don't understand the haters of this idea.
what is it that you don't like? more ways to ensure less screw ups the better for new pc builders.
Its like the warning stickers with warnings like you cant use the microwave for drying your pets. If you need those warnings you need to be institutionalized with someone to take care of you.
They have those warnings in .dk ? LOL.
Then again, they have manditory warnings about substances in computer parts causing birth defects in the state of California, USA.
Nope. We dont have them. Our legal system got a lot more common sense 😉
But this is the root really. People have to think for themselves instead of this curling/helicopter mentality. If you need colour coded sockets you got a lot bigger problems than that.
damn, that is some hyperbole. do you seriously put those 2 issues in the same league? like seriously?
and common sense? just this forum alone I count a min of 15 regular posters with zero common sense.
I don't care about the color coding, but I don't have an issue with it. I do wish they'd make it more obvious on which direction the CPU is to be placed into the socket. The i7 5820K was not nearly as obvious as previous CPU's were. They did not have a triangle to match up like past CPU's had, and instead, you had to line up a couple slots, where were only ever so slightly different if backwards. While I got it in correctly, it took more time than it should have.
People have forced RAM in the slot backwards and fried it and the slot.
The same could be done with a cpu, it could be flipped 180 degrees and forced at least partially down, smashing some pins in the socket.
Color coding won't idiot proof everything.
Bottom left corner. I don't think they produce more then 1 version of this cpu or?
The problem was the motherboard didn't have a matching one. The instructions had you line up slots. Perhaps the fault lies with the idiot who wrote the installation manual.
After a 2nd look at the instructions, it was that little dot on the chip itself that was the only indicator they showed, which is at a different corner than the triangle.
how many motherboards have you seen that have you install an intel cpu upside down or sideways?
i have seen exactly zero.
well btx. but that was 10 years ago.
i retract what i said. apparently every x99 board is an upside down cpu.
You cannot idiot proof anything. When you think you have made something idiot proof along comes a better idiot.
Just echoing what pcgeek said
There is a tv show called the Newsroom on HBO written by Aaron Sorkin. It got a lot of flack when it came out for the author wrote the tv show like you would write a 3 act play where you purposefully present information in such a way where you meet the characters for the first time to purposefully color the impressions of the readers. You make a good person who has a different viewpoint as you look like a complete moron, only for in act 2 and act 3 to show that this person was not the adversary or the rival but instead just someone who had a different viewpoint as you, and that you were just as idiotic and arrogant and this person you though was an asshole is just like you in having good inspirations and wanting what is best for everyone. You do this type of play to "deconstruct personal narratives" and to show how good people with good intentions can still be living in the messed up world for the world even with perfect cooperation would still be tragic for humans find it extremely hard to communicate with one another and see things from another point of view due to something called cognitive capture.
Well in the 2nd episode a very bright and talented women, looked like a bumbling idiot for she made a complete and moronic chain of events for she was not paying attention with her conscious mind on what she was doing and instead using instinct and automaticity to write a damn e-mail.
3 minute youtube clip of the scene I am referring too.
She was ranting about something else to other people outloud with her mouth, while at the very same time being stuck in her own head place thinking about the injustice of the whole situation composing new thoughts in her head while she talked to herself inside her mind, and while doing two other things at the very same time she automatically typed an e-mail and hit send without double checking and thinking things through like if she had the right e-mail recipient before hitting send.
Well we know that those three tasks actually use those same exact brain areas and you can only do 1 of those things at a time with your conscious mind, the rest rely on the automatic mind and automaticity or it requires you being in a state of being where you can be reflective and think and not stuck in a place of cognitive capture.
Thus a very smart women due to emotionality and how she was personally invested in drama made a complete idiotic mistake. This is not something that is sexist or related to women for men make a lot of similar stupid mistakes when we are thinking about something else especially when we are emotionally invested.
Yes in an ideal world Intel would color the cpu socket something different, or including a voice device like you see in greet cards that whenever you open up a cpu box it states big vocal reminders on what you should do before you waste your $40 to $1000 cpu. I am sorry but this is your own damn fault, it sucks for it seems a thing you should not have to consciously think about, double checking if your cpu is compatible with your motherboard before jamming it in their. Placing a cpu into a cpu socket does not require any fancy iq or advanced degree, a middle schooler can do it after he or she has been shown how as long as he or she has the fine motor skills and enough presence of mind to double check the steps before you flip that little piece of metal rod and seat that cpu into the socket even if you are now doing so in a way that would damage the cpu.
Life sucks, people make mistakes like this all the time. How many car accidents do we have each year where people die because we were not completely in the moment and aware of our surroundings before we did something with our two ton instrument of death on 4 wheels?
Instead of getting frustrated and blame intel, you just need to laugh at the situation and be able to look at the dark humor of it all. It is merely money and it was your own fault, hopefully you learn from it before you make a similar type of mistake with real consequences that hurts real people in ways that you can't repair from.
(And to the OP yes your idea by the way your idea is not a bad idea and on the face of it appears to be a good idea, but I am merely explaining why people are annoyed with your suggestion, just like they are annoyed by people who spill coffee on themselves in a motor vehicle and then sue the person they bought the coffee from yes mcdonalds should have taken some easy reasonable steps and not had the coffee that hot but it was still the old women's fault who placed the dangerous item between her legs while operating in a vehicle where the uncontrollable does happen and thus it is partly her responsibility and her own fault).
Maybe instead of rectangular CPUs Intel should make them slightly trapezium shaped.
