Zenmervolt
Elite member
- Oct 22, 2000
- 24,514
- 34
- 91
I always put the most tread on the front...that's another rule people get backwards. I love when people argue with me about 'best tires on drive wheels' vs 'best tires on front.'
Yeah, getting good traction at the drive wheels is totally of the highest importance on a car that can't steer...
OK, now you're just trolling.
There's a reason that street cars are designed with inherent understeer, and this is the same reason that the best tires should always be on the rear wheels. If a car understeers, the instinctive response of a startled and untrained driver (immediately lifting off the throttle and possibly hitting the brakes) is a relatively safe way to correct the issue and even if the car continues to understeer, it maintains forward direction without spinning. This means that if there is any impact, the car's safety systems are in the best position to work properly; front impacts are generally the best-protected impacts that are possible for most cars.
If you put the best tires on the front axle, even with a FWD car, you substantially increase the potential for oversteer and spinning. If a car starts to slide, the instinctive responses of untrained drivers make the situation worse, not better, and because of the spinning the chances for a rollover or a side impact are vastly greater. It's patently unsafe and the only people who recommend putting the best tires on the front are people who have zero understanding of vehicle dynamics and fundamental safety concerns.
ZV
