- Jun 24, 2001
- 24,195
- 857
- 126
I see some discussion elsewhere on the net of removing the anti-glare coatings from several types of LCDs but I'd like to get a discussion going about it here, mostly because I'm too lazy to register elsewhere and they don't seem to apply to my specific situation. XD
Basically, I'm working on an iMac for someone who kicked it and shattered the front glass (not part of the LCD panel). The shattered glass damaged a large area of the anti-glare coating, most likely straight though to the layer underneath, through the screen still works fine. I see that many people soak paper towels and place them all over the screen and leave it there for 12+ hours before peeling it back from the corners (usually take the LCD panel itself apart). The AG removal discussions I see online specifically say not to allow water or whatever they use to reach the layer underneath, which would happen right through the damaged spots if I did this the most common way. I see conflicting information though (some say to use Windwx; other say "never," etc).
Any suggestions for my particular situation? I'm thinking that I should mask off any damaged areas with scotch tape and then soak, but I have a feeling that it will leave the AG coating stuck to the areas that are already damaged, enhancing it.
Anyway, it appears that most people
