Originally posted by: NewBlackDak
I'll try for more, but my motherboard only lets me have 1.4 vcore. That along with crap vdimm adjustment is making me look at these:
EPoX EP-9NPAJ
DFI nF4 SLI Infinity
I have the EPoX EP-9NPAJ-SLi & its a nice board. It is runing my Opteron quite happily on 280MHz HTT. My only criticism is that the vcore fluctuates a lot - it drop s about 0.025 when the cpu is under load & then over-volts by the same when idle. As a result I've had to use a higher vcore than I would have liked. I do use C&Q to lower this when not using it heavily. There's a new-ish BIOS out for it that adds 150 & 183 ram dividers. I'll let you know how it overclocks with the X2.
Just talked to my wife, and she says "programs still open and both boxes are still red, but it's louder than usual". That's 14 hours and counting now!!
That's good news. Get the wife to stop it now - 14 hours is more than enough but if it fails before you get home it will just worry you. That's a typical wife comment to say that its louder than usual. Exactly the sort of thing my missus complains about.
I put the HotFix on, but didn't install the driver. I thought the driver was just for CNQ?
There's an MS hotfix, an AMD driver (which I think you're right is for C&Q) and then there's the AMD optimizer. Personally, I would install all. I like C&Q - it saves power, reduces temperature which keeps my fan below 1000rpm, & it will increase cpu life which, although not relevant for me, might help the chap who buys it from me on Ebay.
