Sha256
Beer4Me
564
20
goddamnit slapped my email into leakedsource.com
https://www.leakedsource.com/
Search completed in: 0.7102 seconds.
Linkedin.com has: 1 result(s) found. This data was hacked on approximately 2012-06-05 00:00:00 What is in this database?
VerticalScope Network (Vbulletin) (939 Websites) has: 1 result(s) found. This data was hacked on approximately 2016-02-01 00:00:00 What is in this database?
Dodonew.com (Chinese) has: 1 result(s) found. This data was hacked on approximately 2012-01-01 00:00:00 What is in this database?
Gawker has: 1 result(s) found. This data was hacked on approximately 2010-12-01 00:00:00 What is in this database?
Anandtech.com has: 1 result(s) found. This data was hacked on approximately 2016-03-15 00:00:00 What is in this database?
The LinkedIn breach was quite public when that occurred, and they even sent emails out to all members about it.
Like I said, Anandtech was hacked back in March, and everyone's password was likely taken. No biggie, right? This password grants a hacker access to nothing. :)
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
I don't blame them for not knowing it occurred at the time. But the data was unequivocally shown to be public yesterday, and the response since then has been wholly inadequate. They covered it up for almost 24 hours and then posted a forum announcement that was frankly deceptive. They claimed password encryption, which is false by anyone's definition. They claimed that because of the "encryption" no passwords were revealed. They presumably base this on the fact that only the hashes exist in the database, but they knew yesterday that a high percentage of those md5 hashes have already been cracked. I say "high percentage" because of the fact that a large percentage of the mod accounts were proven to be cracked, and since the attackers had no practical way to target specifically mod accounts that can be taken as an approximation of how many of the accounts were cracked.
I'll say it again: your AT email address and password HAVE BEEN CRACKED, so change your password here, and anywhere else that you used that email and password combination.
Beer4Me
564
20
Thanks Markbnj!
BxgJ
1,054
123
Is this why I, err, my account briefly engaged in a conversation with Mayne today? :D
On a serious note, thanks for letting us know. Thankfully the password I use(d) here isn't used anywhere else.
14,087
Guessing it uses MD5 + a salt, but never really played with vB.
Personally anything I code that's web based that uses a login that's usually what I do, there is absolutely zero reason to store plain text passwords. Though I have not coded anything in a while. Now days I'd probably use SHA256 whatever is considered the best after some research. MD5 is still better than nothing though, as it will buy you/your users time to change passwords that have been reused on other sites. Ex: forum gets hacked, you advise your users to immediately change their passwords if they use it on other sites. If you/they act fast enough the hacker may not have finished doing a dictionary/rainbow table etc attack yet.
mrjminer
2,739
16
Never use MD5. I thought of a single edge case where MD5 is the best encryption you could use, but it would be the kind of edge case you would want a large team of security experts to consider, as it would require the plain-text password somewhere. Or, it could be useful for honeypotting.
You want to use SHA-512, unless 1028 is out yet (been a few years, don't know if its usable yet). I just checked wikipedia and it looks like the SHA-3 methods have been standardized, so 1028 would be the way to go presumably now
35,609
Interesting, I went to change my password and found that my account email address is pointing to an email address that I've never had.
Viper GTS
38,107
433
You are the second person now that I have seen with that.
No other signs of fuckery, just the changed email.
Viper GTS
mrjminer
2,739
16
That's still a fast hash. Pbkdf2 or bcrypt for the win.
With iterative hashing, speed doesn't make a difference (iirc PBKDF2 is just iterative hashing/key stretching using an underlying method like SHA-512?). IIRC back when I was researching it several years ago, SHA-512 HMAC was always the best solution for ultimate control and security, if you didn't mind rolling your own iterative hashing / key stretching (both not too difficult to do) -- might have been something related to the output length
Ichinisan
28,298
1,236
Gawker was pretty big too. That whole database was immediately released on public torrents. Googling my username would show my plaintext password in the Google search results before I even click anything.
Markbnj
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Yeah but that's the point. You don't want to write your own key stretching algorithm, or really reinvent the wheel anywhere else in this area. So pbkdf2 or bcrypt.
mrjminer
2,739
16
Sure you do (well, maybe you don't, but you could is my point). It actually is very easy once you understand it (and it doesn't take a lot to understand once you start looking into it, really, it doesn't). Like, just running a function in a loop kind of easy.
That being said, I'll note that I don't suggest someone tries to create their own hashing algorithms (ie: I'm not suggesting to do something like make Markbnj-512 to replace SHA-512). Doing so would be ultra-advanced specialty territory. Just that the additional standards are thing you could implement yourself if you wanted without much difficulty.
It just really depends on the level of customization you want, honestly. Are the existing functions like PBKDF2 sufficient to cover things that you would otherwise have to roll-your-own on? Sure. Is that as much fun or give you as much customization or security that you want? Not to me :D
Markbnj
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Mmm, I think security is a different animal. I'm not afraid to create my own implementations, but I wouldn't in this area unless, as you suggest, there were some requirement that couldn't be fulfilled any other way. I feel that situation is highly unlikely to arise, though.
rh71
52,844
1,049
I used to run fusetalk (coldfusion) just to play around with it and it was stored as plain text... it was pretty... remarkable.
Ns1
55,420
1,600
O_O
14,087
I wrote my own hashing algorithm a while back just for fun of it. I would not trust it for security mind you and it's not even meant for that but it was fun to do. Basically I have this small app that is used to just go through source/header files and it just puts a generic header block with lines of code, last modified date etc... and I just needed a way to detect if a file changed so I'm not repeating that process for nothing on each file, so the hashing algorithm is used for that. I wanted the app to be portable in a single .cpp file that will compile on any system without the need of dependencies, and the hashing algorithm is just a single function. It will of course work with any length of data, whether it's a single character or a super long file. For my purposes I actually needed it to be fast, so it does not do anything fancy. It's mostly a combination of adding, subtracting and multiplying. What is at one end of the data stream can affect how another end of it is handled, so changing a single character anywhere ends up with a competently different hash value.
IEC
14,608
6,094
You shouldn't use the same password anywhere else anyways. Especially not with this forum (or many other forums) because they don't even implement TLS.
tl;dr --> you should not expect any privacy, and if I was on the same network as you I could probably grab your password in plain text with trivial effort as you log in.
