SGI 17.3" LCD monitor plus Dell System for $1680 after rebate
pagoda
This is an unconfirmed deal, but I plan on ordering this within a week...
Go to http://accessories.us.dell.com/sna/productdetail.asp?sku=603103-5
and add the SGI 1600SW LCD monitor to your Dell shopping cart.
Notice the MSN Passport checkout is not available here.
Then go to the MSN Passport 20% off deal at
http://eshop.msn.com/softcontent/softcontent.asp?scmId=579
Click on the link to Dell4Me.com
Click on the cheapest system Dimension L Series
Dimension® L600cx, Intel® Celeron? 600 MHz
Remove the 15" monitor to cut the cost down to $589.00
Notice the MSN Passport checkout is now available.
Your final price comes out to less than $2100 in most cases
Minus the 20% off rebate.
The final total is only about $1680!
The monitor itself costs $1400+
So you're technically getting a computer for only $280 shipped!
Did you actually tried it? When I check out from MSN/Dell4Me, the monitor is gone from the shopping cart. However if you go back to the monitor link, it's there but with no computer (although I saved my cart from Dell4me). Appearently you can not combine these two carts. I don't know if this is because they are smarter or more dumb, i would think it is the later.
