- Dec 1, 2000
- 1,235
- 0
- 0
In case anyone else with a Linksys router is monitoring this post, here is Linksys's response to my email:
Thank you for contacting Linksys Customer Support.
In using MSN Messenger behind the router, uninstall any personal firewall programs such as BlackIce, Norton Internet Security, etc.
Forward ports 6891-6900 to enable File send
Forward port 6901 to enable voice communications
Note: disable SPI and Block WAN Request as these will cancel all forwarding attempts
IN TCP 6891 - 6900
IN TCP 1863
IN UDP 1863
IN UDP 5190
IN UDP 6901
IN TCP 6901
If you're using an old firmware, you may want to upgrade to a newer one.
If you still experience unstable connectivity even after flashing the latest firmware, it is expected to be addressed in the next firmware release. We are continuously doing tests regarding MSN Messenger applications behind the router.
I have also attached a document regarding Port Forwarding.
If you have further questions, please feel free to send an eMail
to support@linksys.com or contact us at (800) 326-7114 so that
we may further assist you.
IN TCP 6891 - 6900
IN TCP 1863
IN UDP 1863
IN UDP 5190
IN UDP 6901
IN TCP 6901
