- Dec 1, 2000
- 1,235
- 0
- 0
I have a few annoyances that I thought I would throw out to the experts for help! My XP/Linux box is running super stable, but these things are just irritating to me:
1) While my CD-ROM is running, my sound is choppy... Otherwise it is fine... for instance, if I have an MP3 playing and the CD-ROM starts spinning, I get bad choppiness in the sound. I tried to reinstall WinXP as a "Standard PC" with no ACPI (as his been suggested to me), but it hung on installation with this option each time. I HAD to select ACPI to get it to install. Also, I get occasional popping when certain apps start if the CD-ROM is running (for instance, when I get an IM the sound is crackly).
2) I no longer am able to do voice/video/file shares on MSN messenger. Each time I try to connect with another person/computer, it will eventually not work and say it is "disconnected" or some such thing. I suspect that it may be because I am running through a Wireless router (Linksys), but I am stoopid enuff to not know much about networking and how to resolve this.
3) I also have a laptop on my wireless network that can't seem to do file shares with my desktop. They can't find each other on the network, although I have managed to get the printer shared from my desktop box and the notebook is able to print remotely (although that sometimes doesn't work as well).
4) How long does it take to install things these days? For instance, it took about 20-25 minutes for MS Flight Sim 2002 to install on my machine...? maybe that is acceptable, but it seems really slow. I have a 52X CD-ROM and a 7200RPM HD installed. I used to be able to check the DMA status of my drives in control panel, but that seems to have gone away in XP. Do you think that I am not running things the right way, or am I just being impatient.
As usual, thanks for your help!
