BallaTheFeared
Even when you're doing it wrong, you may continue to do so as Intel proved.
If you look at the benchmarks and application results, comparing a stock 2600K versus stock Q6600, the SB core is more than twice as fast for a single thread and with 8 CPU intensive threads, the 2600K is upwards of 2.5x faster than the Q6600.This is with my Q6 processor. Sandy bridge I heard gives it a 50 percent boost in power. That is nice.
The problem for AMD is Intel's 4 cores with HT matches the throughput of AMD's 8 core. Or if using a car analogy, do you need AMD's 8 passenger minivan if Intel's sports sedan (4 core i7):But the thing is I need cores. I am a believer a true core is faster then a threaded core. At least AMD since 2007 has moved on to 8 core processors while intel is 4 core. and if you want 6 core intel you pay 600 to 1k. While you can pay 300 and get the fastest amd 8 core.
FM2=Upgrade path? 😕My sister recently asked me to build her a complete system for $600. I priced it out and I'm building her a very nice trinity system built around the A10.
She will have her A10 quad core at 3.8ghz, 16 gigs of ram, a 60gb ssd and a 21 inch wide screen monitor + an upgrade path.
I could not do that at this price point with Intel.
lol - I don't understand those choices at all.
Dell has been selling AMD systems since 2006.I suppose to each person, his/her own.
Another reason Intel gained such a lead in the CPU market was because of exclusivity deals with manufacturers such as Dell. AMD never had a chance to enter into the mass market.
Bulldozer has 2 ALUs per core, Haswell has 4. Bulldozer can sustain 1 x 128-bit FMA vector operations per core, Haswell can sustain 2 x 256-bit FMA per core.Here is where I think AMD is trying to move forward while Intel is on a dead stop.
IMO for hardcore users not gamers. Cores are more important. Since 2007 Intel desktop has been quad core. That is not enough if you have 50 synths playing in realtime and 100 plugins in the project. This is with my Q6 processor. Sandy bridge I heard gives it a 50 percent boost in power. That is nice.
Bulldozer does have 8 integer cores,but it has only 4 floating point units. So its performance versus 4C/8T devices like i7 in MT tests that tax the SSE/FP math is expected. Unless you expected that 4 AMD's fp units that can run 8 threads magically outperform 4 SB's fp cores that can also run 8 threads. If nothing, workloads like x264 and handbrake show how good those 4 FX fp units can perform if there is proper software support(both i7 and FX run avx for instance).If you look at the benchmarks and application results, comparing a stock 2600K versus stock Q6600, the SB core is more than twice as fast for a single thread and with 8 CPU intensive threads, the 2600K is upwards of 2.5x faster than the Q6600.
Comparing a highly overclocked 2600K at around 4.7-4.8 GHz with your overclocked Q6600, you would see roughly a 2X increase in throughput if you can feed it enough threads.
-also carries 8 people at the same top speed as AMD's minivan,
-when carrying 4 people or less, Intel's sedan is 60% faster
-has twice the mileage
And if the sports sedan is too expensive, there's Intel's family sedan (i5). It only carries 7 people but otherwise performs identical to the sports sedan.
I've been using AMD cpus since the socket A days, but I do believe in giving credit where credit is due and there's a few inconsistencies in the original post that need to be cleared up.
First Intel was indeed first to introduce a dual core cpu, the Pentium extreme 840 smithfield was released in April 05'; around a month earlier than the Athlon X2. Although it was $1k and lost to the cheaper X2s released in May.
Second Intel had a quad in Nov 06', it was the QX6700 and it was another $1k processor.
If I'm not mistaken, Intel cut every corner possible for their first 'dual-core' by essentially welding together two separately functioning processors.
Okay, there's a joke about the three-boob chick from Total Recall in there somewhere, right? :whiste:You know your sticks of dram aren't made from just one memory chip, right? They essentially weld together eight functioning chips to make one stick of ram, pretty much always have.
AMD is awesome I don't know why people hate on them.
AMD 64 one of the best CPUs ever made
AMD X2 one of the best CPUs ever made. Still using this. :thumbsup:
AMD Phenom II X4 and X6 some of the best CPUs ever made.
For the price Phenom II's are still one of the best chips you can get for gaming!
If there was no AMD Intel chips would be hundreds of more dollars.
Actually, you could go even cheaper with an AMD system.
For $600, you're doing it wrong..
Intel i5-3570K: $190
Z77 Motherboard: ~$100
8GB DDR3: ~$30 AR
80GB SSD: ~$40 AR
430W PSU: ~$30 AR
AMD 7750: ~$80 AR
Budget case: ~$30 AR
That's $500, with rebates but these are all prices I've seen within the last 3 weeks. And it will be an extremely powerful computer.
Those prices look a bit iffy to me (assuming they do not correspond to used parts). In any case, you're still 8 GB of RAM and 1 monitor short matching that dude's Trinity build.
They are not; I just built a system using those parts. Microcenter has i5's for 190 and 50 off any motherboard (thus 100 or less for a motherboard, plus tax). And the sum adds up to $500... leaving $100 for a monitor. Going from 8GB to 16GB is another $20 ($50 AR from Newegg).
All of these prices have hit newegg/microcenter in the last 3 weeks.
The way the newegg emails have been hitting my inbox this past month, I'm going to wait to cybermonday because at this rate they'll be giving away hardware for free by then 😀
