Setting Vcahce for 328mb.
ShiftKart
191
I've researched the hell out of this one on 'Google' and found many,many different views.
Can I hear from you guys, 'da pros on this?
After sticking in a stick of 256 and 128mb of ram, should I just leave it, or change some settings to accomodate the added ram?
Thanks guys.
*TG*
Noriaki
13,640
256+128 = 384 not 328...
But either way you shouldn't have to adjust anything, it's over 512MB that you start to get problems.
ArchAngel777
5,223
61
<<< But either way you shouldn't have to adjust anything, it's over 512MB that you start to get problems. >>>
DING DING DING! That is correct. However if you plan on using Windows XP or Windows2000, you don't ever have to worry about any of that. I believe WindowsMe does not require the Vcache setting altered until 768. Though I am only 99% sure on that one. But as Nori said, the problem for Win9X is when you have MORE than 512, so even 512 is fine.
GJG
ShiftKart
191
Ahhh.... what a dumb-a$$. Did I had 96mb? instead of 128??? :)
Anyrate, thanks for the feedback.
BTW its for W98, later to be XP.....
Later-0
