- Mar 31, 2003
- 11,679
- 0
- 81
For Christmas I came home from College to be pleasantly surprised by the beginnings of a fabulous new HT System.
Right now we have:
Scientific Atlanta 8300HD Digital Receiver/PVR
Panasonic 50" 1080P Plasma HD TV
Up converting (1080i Max) DVD Player
Sony Receiver and Satellites with Powered Sub
First off, I set up the system, but I am having slight problems. I can't get 5.1 signals consistently.
Next, I am almost 100% positive I am correct but just wanted to verify:
I have the Coax cable going into our 8300HD. From there we have an HDMI cable going into the TV. We have a second HDMI cable going from TV into our DVD Player.
For audio purposes (Since our receiver does not have HDMI) we have a TosLink Optical Cable going from the receiver into our 8300HD. We have a Coaxial Digital Out cable (Since our receiver has one TosLink and one Coaxial port) going from our receiver to our DVD Player. Is this the optimal setup given our components?
Finally, I set everything up using 720P. Since NOTHING, save for BluRay, uses 1080P , from what I understand 720P is equal to or better than 1080i (Though the difference is supposedly negligible). Any opinions either way here?
The DVD Player and the Receiver are definitely holding the system back in my honest opinion. But seeing as we have the new expensive equipment I am going to advise my Dad on a few purchases:
Power Conditioner : Is this necessary. We have a surge protector hooked up, but on many nice Home Theater setups this can eliminate a lot of potential problems (High Ripple on AC Lines, EMI etc...)
A new receiver and Speakers. He wants to get another all-in-one system but I am begging him to reconsider. Is it possible to build a decent 5.1 system for ~$5-600?
Finally, he isn't going for it, but I have been begging for BluRay as right now nothing else is using 1080P and DVD's just plain don't look as good as they used to- even when up converted.
Anything else we should be looking at here?
-Kevin
Right now we have:
- I had the DVD Player set up for Bitstream Audio Encoding but I wasn't receiving any audio signal through our Receiver and Satellites. My initial reaction is that the receiver does not have the APU which will decode the raw audio stream. So now it is stuck on 48hz PCM (From what I remember)
- I cannot get a 5.1 channels from any of our channels- even the Digital HD ones which are clearly in HD. It is just stuck in 2.1
-Kevin
