Setting up a webserver from home using my own BW
purbeast0
53,752
6,629
So I just installed Apache2Triad and am trying to get this thing working. I edited the httpd.conf file and only really changed the IP address part to my IP address because I was not sure of what the other stuff was all for. I'm a complete newb to this and so far that didn't work. When I try to connect to the site using my http://ipaddress:80 it goes to my router setup.
could someone lead me in the right direction please? i'm trying to get this gallery of my trip to aruba setup, thanks.
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
It sounds like port 80 on your network is reserved for getting to your router settings. You have two options:
1) Change the port your router settings are on to something different; say, 8080. There should be an option to do this in your router config web page.
2) Change the port Apache is running on to something that isn't port 80, since the router is using that.
In both cases, remember to forward the port on your router to the computer you're running Apache on.
xcript
8,258
You may need to disable external access to your router's web-based configuration interface and forward port 80 to your server box.
AgaBoogaBoo
26,108
Route port 80 and other ports like 21 (FTP) to the server
Feel free to contact me if you need help, I've run a few servers out of my home in the past.
BigJ
21,330
Make sure you're ISP isn't anal about running servers before doing this.
MustISO
12
Are you using an internal IP or external. Most routers use 192.168.x.x which is NOT external.
You may also need to forward port 80 to whatever server you're using.
purbeast0
53,752
6,629
I am using the external IP. I have apache server up and running on port 80 and forwarded port 80 in my routers settings as well. i haven't edited the httpd.conf file at all yet. i can't get to connect to even http://localhost
anyone have any ideas?
chuckywang
20,133
Hmm....I don't know much about Apache because I use IIS. If you have Windows XP Pro, you can use IIS as well. I think it's simpler. However, I think there's a limit of 10 connections at a time for IIS.
vegetation
4,270
My guess is that your router doesn't support loopback, or has it disabled. Try doing a direct plug in to your modem for a few minutes and see if that's the issue (might need to push the reset button on the modem). Don't know what you're running fo a router, but a lot of the newer wireless belkins don't support loopback.. pretty much everything else does though.
purbeast0
53,752
6,629
I'm using the WRT54G router.
chuckywang
20,133
I use that too. http://localhost works for me.
purbeast0
53,752
6,629
did you have to make any kind of changes? What did you install? I installed apache2triad, rebooted, and it would not work. maybe I should uninstall and just install Apache on its own and go from there ...
jiggahertz
1,532
What happens when you go to http://localhost:port? Have you started the apache service? I'm not able to access my webserver using it's external IP from inside of my own network, have to use the internal IP instead. What OS are you using?
chuckywang
20,133
I'm not using Apache. I'm using IIS. It's not as good, but Windows XP Pro comes with it.
