Setting the min fun speed higher?
Zoom123
101
I have an Asus P8P67 Pro motherboard with an overclocked 2600K at 4.5GHz and Hyper 212 Plus for cooling.
Is there a way to set the minimum speed of the Hyper 212 fun higher? My problem is that with even minimal CPU activity the fan changes speed to a higher one and it is a bit annoying to listen to it changing speeds constantly. I would prefer if the minimum speed was higher so it wouldn't need to change speed as often (only on really high loads)
Thanks.
BoomerD
66,726
15,126
Dude...you should always keep your fun at maximum...any less and life would be boring. :p
T_Yamamoto
15,007
795
Stop trolling :p
Op just change he fan on the thing. Or go going into bios and change the fan speed
Sent from Galaxy Nexus (4G/LTE)
Elcs
6,278
It should be possible via the ASUS A.I. Suite II software available from the ASUS website.
