SETI@Home Wow!-Event 2019
Markfw
May 16, 2002
27,094
16,014
OK< so I have one result so far on my 2060. Is 130 seconds good ? 1370 run time, 130 cpu time. The cpu client takes 4750 elapsed on a 3900x running over 4 ghz
TennesseeTony
4,330
3,800
www.google.com
To determine if a run time is good or not, we would have to also know which task was being run.
If running on Windows, go here to download and install lunatics ( click on " Lunatics Installer v0.45b6 (64-bit) "...just click click click until it gets to the Nvidia page, then select the bottom item, SoG, and click click click to the end. Restart, and you should only get SoG tasks, and let us know the run time on those tasks please. :)
Markfw
May 16, 2002
27,094
16,014
OK< does the below look like its doing what its supposed to be doing ?
Markfw
May 16, 2002
27,094
16,014
Well, now that I have 15 valid results, its very odd to me the credit/runtimes, very inconsistant., 14 seconds to 911 seconds. Points run from 1 to 79, but the 911 was only 65 points. Most appear to be in the 70 something points, but the run times are all over the place.
lane42
5,721
624
Mark, those fast workunits with low credit are just what are called
Noise bombs, bad data in the workunits and this will pass.
Reactions: ao_ika_red
burninatortech4
729
419
SETI@Home shows validation pending on 91 tasks. I'm not sure why its being so sluggish to provide credit. My dad's 2200g machine has more credit for the same time period than my 2700x/Vega 64 ???wtf.PNG
StefanR5R
6,551
10,291
Isn't this standard for SETI@home? (I run it only occasionally.)
You can look at the Work Unit of some of your pending results and try to get a picture of the computers of your wingmen.
I clicked through some of my own pending results as well as a handful of yours, and the wingmen had returned valid results generally very recently = hours or minutes ago (for other workunits than our pending ones). That is, all which I have seen are actively processing their work queue.
In other words, among the sample of pending results that I looked at, I haven't spotted a wingman who blocked the uploading of results (e.g. in order to release them after the Wow!-Event starts).
Assimilator1
24,152
517
So how much more efficient is a GPU for SETI these days?
And for my main rig, which would be better? (obviously both is better overall ;)).
Oh yea, and I'm in :).
In this event we want to crunch what we can. Therefore, of course, the CPU should also count.
Err, that's not what he asked ;)
StefanR5R
6,551
10,291
I don't know for AMD GPUs. But in case of Nvidia GPUs, their efficiency depends quite a lot on whether or not optimized application versions are installed. Especially those that are available for Linux make a difference.
Last year I posted PPD/Watt for 16nm Nvidia consumer GPUs and 14nm Intel server CPUs.
Edit: Found the post.
Edit 2: The post shows power consumption at the wall, hence includes the CPU overhead of the GPU application, and other overhead of the host hardware.
This showed a power efficiency (credits per second per Watt) of 2.4 points/kJ for the CPUs, and 3.1 points/kJ for the GPUs.
Meanwhile, I suspect credits per computational work may have eroded somewhat, while computational efficiency of CPU-only application versions presumably have remained the same. (I have yet to verify this.) On the other hand, Linux Nvidia CUDA application versions appear to have almost doubled their speed from spring 2018 to winter 2018/2019, at only slightly increased power consumption.
ao_ika_red
1,679
715
SETI seems to take much longer to validate than Milkyway@Home. Interesting.
Bear in mind that a lot of people are bunkering right now and seti user base is a lot larger than mw@h. For easy comparison, you can compare TeAm's seti and mw@h users on tony's weekly stats.
burninatortech4
729
419
Looks like my Vega 64 (Sapphire Reference) at:
1630mhz [1090mv core] and
1000mhz HBM
is completing [blc33_2bit_guppi_58643] in about 11min 16s
https://setiathome.berkeley.edu/result.php?resultid=7852588092
2700x PBO temp on 100% load is stable at 77 Celsius (30 Celsius ambient) with a Dark Rock Pro 4 at 1544 RPM - SETI runs hot!
GPU is comfortable at 57 Celsius Core and 66 Celsius HBM
I was able to reduce task time for my Vega 64 down to between 7 and 8 minutes (from over 11 min) by setting CPU to 90% max (leaves a core and 2 threads open). I'd read about doing this but hadn't tried it yet.
TennesseeTony
4,330
3,800
www.google.com
I will stick with the current PG challenge until the end......as a make-up for absolutely sucking at running SETI. I will have ONE 1080Ti running SoG for SETI (Winblows 10). I absolutely LOVE SETI as a project.....but HATE it due to not being optimized 'out of the box'.
Dear @Pokey......we hope 'retirement' from DC has treated you well friend!!!!!!!
Reactions: StefanR5R
TennesseeTony
4,330
3,800
www.google.com
I just msg'd Pokey.....I know he is retired from DC (same as biodoc, lol!) but I'd sure like to know he is still among the living. :-/ SETI was his favorite....
StefanR5R
6,551
10,291
The SETI WOW event is soon. If you're good with multiple clients and bunkering, that race started over a week ago! :)
I'm way behind the curve. I still haven't fixed the recently discovered trouble with the circuit to which the GPU-equipped computers are supposed to be attached. It's not something I want to deal with when tired from a workday...
I could run a long power chord across a couple rooms, but aesthetic concerns aside (feeling all nobby about that), it would introduce a tripping hazard at best, and at worst just shift the latent fire hazard to another circuit. :-(
Modular
5,027
67
Those 1070s would scream in Seti on Linux. It's really easy too:
Install mint
Update
Install driver 430
Download the special linux client
Extract to Home folder
Change settings in .xml to cuda 101
Run boincmgr
Login to Seti
1min 30 second Wu's abound! I hope you relinuxify!!
