And they're accepting more users again...
Answering some questions a little later... (must read them first....)
Edit, he he, posted at the same time as Sir Ulli.
Anyway, to answers...
Smoke
BOINC - 11/19/03 09:55:21 - Suspending computation and file transfer - user is active
BOINC - 11/19/03 09:56:17 - Already attached to [L=http://setiboinc.ssl.berkeley.edu/ap/http://]http://setiboinc.ssl.berkeley.edu/ap/
BOINC is on but doing no work?
This is due to the default preferences all new users has got, there they've suspending BOINC for 3 minutes if you've hit a key or moved the mouse or something... So before you've got fixed the preferences, change to Run Always. (either right-click boinc-icon, or file-menu)
boinc_gui is of course using only 0% cpu, if this is high something is seriously wrong...
BTW, in seti, it's currently 2.08.
😉 If astropulse, ap_2.11_windows should show up in Task Manager.
Wiz
My questions:
when does it return results?
Looking in the Work area it shows 3 units as "ready to report" - why does it not send them in, does it wait until all the work is done for all that it downloaded?
Is there a way to only do setiathome if I wanted, it downloaded 4 units of seti and 6 units of AP?
If you've got an usable connection at the time, it will immediately return the result, and change to "ready to report" then uploaded.
It's on "ready to report" till you next time connects the scheduling-server, either then your cached wu drops below it's min-setting, or you manually hits "Update" under Projects-tab.
Hitting Update will also get new preferences, if anything changed...
As for only running the seti-wu if you've downloaded them, AFAIK the only way is to go into your favorite file-deleter and navigate to ..\boinc-dir\projects\setiboinc.ssl.berkeley.edu\ and delete all wu that's starting with ap_date_numbers_numbers_numbers.wu
Of course, since this is a beta-test and nothing is counted anyway to the stats, I don't really see a point to not crunch all wu you've downloaded...
--- regarding machine-listings ---
The "public" listings if not disabled this, is only listing "the rankings of the machine", Owner, recent average, total, cpu-type, OS, results.
Then logging in to an account, "the rankings of the machine" changes to your local computer-name. So if you've got a computer called Smokie as part of the domain lost_my_balls.com it will be listed as Smokie.lost_my_balls.com
You'll also get listed the local ip-address of this machine, and how many times it's been this... So if you've got the account-key, there shouldn't be any problem knowing which machine has got assigned a wu and how much time you successfully used to crunch this or it got corrupted in download or something... (this machine-listing is currently disabled)
Then re-installing BOINC or re-setting the project, you will get multiple listings of the same machine. It's possible to merge this listings, always the older to a newer machine... Then merging you will get a list of which machines you can merge with, and at that time each machine-profile was made...
--- regarding crediting ---
There will not be any credit before at least 3 "successful" results is returned. AFAIK they're still not using a real validater, but AFAIK currently all using less than 10000 secounds is seen as bad... In Seti, I've not seen anything to any credit yet, but they will hopefully enable this also...
You can for each machine hit on the "results"-part and get a listing of that wu you've got assigned, and their status in your crunching. The 1st number in this listing is the wu-number, and then hitting it you get a listing of all machines that's got assigned this wu, and their outcome... Not very encouraging then you've used 30000 seconds on something and the only other "successful" is less than 60 seconds...
BTW, credit is the average after removing the highest & lowest "claimed credit" to a wu... With normally only 3 wu then averaging, this is of course the middle... Later successful validated returns will get the same credit, they'll not re-average... Of course, how many results to use is project-specific.
NOTE, currently the personal listings of machines & results is down, so not all info is available. It's only the public listings that's up. :frown:
NOTE2, if preference-changes doesn't take immediately after downloading new, exit BOINC and re-load. Atleast changing #cpu on multi-cpu works this way...
