Seriously, there is a clear difference between 128kbps MP3s and CDs.
Originally posted by: virtualgames0
I'm sorry everyone to downplay all your obsessiveness to lossless audio.
I know it made you guys feel really bad and defensive, but the truth hurts sometimes, and you need to learn to accept it, calmly.
i rip at 192k, because that's the point at which i can no longer hear the difference. how is that lossless? what other usernames of yours have been banned?
Yep keep on telling yourself that, so you can justify all the extra space and time you waste on lossless compression formats.
i don't tell myself anything. i hear it. maybe because i'm listening, or maybe because i'm not listening to crap music that hurts my ears. i dunno.
Originally posted by: KoolAidKid
Originally posted by: Howard
Verbal sparring will get you nowhere.
If true, then nearly all posts in ATOT are a waste of time. Actually, this seems about right to me.
Yeah, but at least the vast majority of posts actually contain some real thought - and besides, most people just naturally try to play (argue?) nice. This dude is completely inflammatory.
Oh, and I think I owe $0.25 to werk now.
I bet it's in your head..
Go ahead and go to best buy and buy your $20 /pair KEF bookshelves. You obviously can't tell a difference in sound from mp3 and cd, so why bother with even a HTIB?
Did you miss the part that I used a $2000 mcintosh amp with a pair of sennheiser hd497 headphones?
sure didn't miss the part where if fraunhofer says something is true then it's gospel.
True, the vast majority... only if you don't count "off topic"
Replace Off Topic with Politics and News... 🙂
Essentially, comparing CD's to MP3's to is comparing the relative amount of stench from different turds. They're both brown and lumpy and they both smell bad, but I'm not ready to say whether they smell identical.
So at least harvey does admit that they are pretty close.
OK. You got me. As long as my name is being tossed about, I guess I have to define my own statements. If that's what you think I said, it appears your reading comprehension skills are similar to your expertise in listening.
Yep I'm not skilled enough to see the night and day in the 4% difference. I was an asshat, being ignorant to the fact that to most ATOTers, the 4% was night and day.
Actually, you, and most ATOT members are skilled enough to hear the differences, just not in the way you're trying to define them.
It starts with the idea that art transcends the medium. That is, musical art is more than just counting to four and getting the righ notes in the right places. Real musical art communicates emotion, and anything that gets in the way of that and changes the original sound composition (master recording) can alter and undermine that emotional transfer in very subtle ways. Listening for differences on a first person present conscious level is not the same as kicking back and allowing the music to give you the artist's intended sonic experience.
I am both a musician and an audio electronic design engineer, and I've posted the following explanations, including the above comment about music and art, a couple of times before, so please excuse the redundancy. I hope you're in the mood for a read. 🙂
Anyone who has seen my previous posts knows I think CD's suck compared to original sounds for two reasons -- 16 bits just aren't enough, and the sampling rate (44 KHz) is way too low.
16 Bit Quantization
The encoding scheme is linear PCM (Pulse Code Modulation) which quantizes levels as a linear function (bits per volt) while your ear perceives sound as a log function (decibels = dB). As the signal level gets lower, you have fewer bits to resolve the details of the sonic image, so the distortion rises as the level goes down. Meanwhile, human beings tend to tolerate more distortion at higher levels and to be more sensitive to distortion at lower levels, because that is what happens with both your own ears and most real world sound generators like instruments, speakers and amps. In other words, when it's full bore blowing your own ears into distortion, it's as clean as it's going to get. In a moderately soft passage, where your ears are more sensitive to distortion, CD's are glad to give you lots more distortion.
It's like dot matrix lithography without enough dots per square inch (the equivalent of frequency response) or a good enough grey scale (the equivalent of dynamic range). A young man can get off single handed if the image is up to Playboy centerfold standards 😉, but IMHO, 16 bits x 44 KHz is the equivalent of crude newsprint.
If the system encoded the signal as bits per dB, the distortion would be constant. However, that is a much more difficult system to build. Furthermore, the current system is already in place, and it would still require more bits to achieve acceptable results.
44 KHz Sampling Rate
44 KHz is an inadequate sample rate. This sampling rate was chosen based on Nyquist's theorem, which states that, to recover a given frequency, you must sample the information slightly more than twice the highest frequency. The problem is that Nyquist wasn't a musician. As you get closer to the high end of the audio spectrum, this theorem is only valid for a single, steady state tone. If you change the conditions to allow for a second tone, or to modulate the amplitude (volume) of the sine wave while it is being sampled, you have created a condition where there are literally an infinite number of possible outputs for a given sample.
As a designer of analog gear, when people ask me how many bits I want, I always answer, All of them! 🙂 No matter how many they have, I have more. 😀
More Problems
Another problem is, the inherant distortion in CD's is non-harmonic. That means, unlike harmonic distortion (THD), the distortion products are out of tune with the music, which, in turn, means that human beings are far more sensitive to this kind of distortion. That is why I said that, to some extent, the inherent distortion of most analog systems is more tolerable than typical distortion found in PCM systems.
As I said, I used to be a professional musician, too. Music (and any art form, for that matter) transcends the medium. It isn't just counting to four and getting the notes in the right place. The subtle undertextures of a musical performance are part of the "magic" that moves your soul. When I turn off the scopes and meters and just kick back to play or listen, CD's don't cut it. I have CDR's in my machines, but I don't own a CD player.
< update >
I now have a CD player for reference in my work.
< /update >
If you want to hear the difference, get ahold of an old LP in good condition of something that was recorded analog, and a CD re-issue of the same thing. Cue them up so they are in sync, and switch between them. LP's win every time. Good examples would be Eagles, James Taylor, older Steely Dan and anything else with good air space in the recording.
It could be worse. MP3's suck even more than CD's. :Q MP3 is an example of a "lossy" system that discards information some machine "thinks" you can't hear. PKZIP is an example of a lossless system. The data storage footprint is compressed, but you get all the data back when it is decompressed. The information lost in lossy compression is usually subtle stuff, but I have participated in experiments that prove you definitely can hear the difference.
There is hope on the horizon.
The highest standard for the new audio only DVD is two channels of 24 bit data @ 192 KHz with only lossless compression. At that sampling rate, it will once again matter if the analog electronics I design can do a good job of reproducing the signal. 🙂
Don't worry. It's a multi-format standard that is compatible back to current CD's, so you'll still be able to play them. Of course, once you hear the new stuff on a good system, you may not want to, anymore. We may finally be about to come out of the Audio Dark Ages[/b]. 😀
< update >
DVD audio is a reality. It is not the dominant release system, and it may not become the standard for inexpensive mass distribution, but at least, it is not a forgotten wish, and musical masters can be stored at a resolution worthy of great performances. :thumbsup: 😎 :beer:
well, that one too.
Originally posted by: IHateMyJob2004
This raises another important point. Some people simply do not know how to listen to music. Not an insult. But if you are not interested in hearing good sound quality, you can never understand what bad sound is.
If that isn't some of the most elitest bullsh!t I ever heard, I don't know what is.
Harvey,
Thanks for your informative post about why current audio cds sucks. I don't dispute the fact that other mediums sound better than cds
I do understand what you are talking about when you talk about art and emotion as I am a musician myself, contrary to the belief that I'm acoustically challenged. I have played flute at a band/orchestra in all through gradeschool, and now college, and I have taken several private lessons. Believe me, playing the flute takes an immense amount of art and emotion.
My neighbor has a lot of very high quality recordings of classical music, and often plays a few of them for me on his $15,000 audiophile stereo equipment(the mcintosh is a "cheaper" amp for his son's room). A few pieces sounds almost like the real thing, but just not quite there.
I am disputing the fact that full uncompressed cd quality audio have very little/no distinguishable difference from a decent mp3 bitrate counterpart such as 128kbps for most recordings, and 160kbps for higher quality ones. So what is your own "professional" findings on this?
actually it's not. some people just throw whatever on and it doesn't matter if it's cd, am, fm, whatever. they don't care, it's just something to distract them. then there are people who are looking to get something out of their music, they listen a little more closely. then there are people who listen for every last detail. different levels.
I think there is a noticeable difference when doing a/b comparisons, but on the other hand I don't think that difference is as significant as the difference between good music and music that sucks.
Being able to distinguish between MP3 and 44.1k 16-bit WAV is more of a liability than anything else, IMO. Sure, you can probably train yourself to be able to discriminate between the two, but why would you want to? All it does is require you to use more hard drive space to store your songs and more expensive audio equipment to play them.
This reminds me of a upgrade junkie I know who upgraded his processor from a 2.4 to a 2.8 GHz CPU. He couldn't really tell the difference between the two, so he ran the system through all sorts of benchmarks so that he had something to point to when asked to justify the cost of the upgrade. The same thing goes with high-end audio gear: people buy it and then train themselves to be able to tell the difference. If they didn't do this they wouldn't be able to justify spending the money in the first place.
Actually, alot of audiophilles are also musicians. Due to this, they know what live music is supposed to sound like and they strive to duplicate the live experience with their audio gear.
And those audiophilles that arn't musicians like to go to live concerts. They appreciate good sound just as the musicians do.
I'm a musician, and really, 128K mp3s don't sound THAT bad to me. I can hear a difference, but I can ignore it for the sake of enjoying the music.
I think if you can't enjoy music when it's not pumping out of an 'audiophile' stereo, then it's YOU who needs to learn how to listen to music.
i certainly don't think music needs to be puming out of a 15k system to enjoy it, but when it sounds like ass it just distracts me more than anything.
do the same thing with a complicated sonic spectrum like classical or rock with distorted guitar and loud cymbals and you can hear the difference in the high frequencies pretty easily. MP3's have a sort of waving, almost fluttering high end, which isn't a good way of describing it, but it's very distinctive.
you're not gonna hear it on electronica though, because none of the sounds are dense and they are all heavily processed and not natural to begin with.
I listen to my music very closely, always listening for interesting sounds I can sample and whatnot. However, that doesn't mean that I "know how" to listen to music. That means I listen to it differently than others.
I'm not interested in hearing 'good sound quality' because it's not so good as to justify the cost required to do so. Most people fall in the same boat as me. The 'huge' differences you audiophile types hear is all in your head. Its all mental masturbation.
If you want to hear music the way it was meant to be played, buy a set of studio monitors.
quit using the blanket statement "you audiophile types" because you are lumping people who don't like to listen to AM radio quality sound into a group of folks who feel the need to spend a grand on a speaker wire. it made the OP sound ignorant and it doesn't make you sound much smarter. maybe "know how" is the wrong choice of words, perhaps "care to listen" would be better.
I agree that I don't enjoy music as much when its coming out of a crappy little boombox or something like that, but really, the differences between my parent's bookshelf stereo and a $20,000 stereo aren't so much as to justify the price. The differences between 128K mp3s and lossless or CD audio isn't so much as to make the music unenjoyable, unless we're talking classical music or something with a lot of highs and a lot going on in the midrange.
My hearing is fine, by the way. I can point out the differences between 128k and 160k, I just don't care to because if I spend all my time doing that, I'm not really listening to the MUSIC.
If you can't enjoy a 128k mp3, you're a mentally masturbating audiophile type, period.
i can't do that, if i'm listening to something that has bad reproduction it just distracts me from the music. i don't spend a ton on gear, but i at least try to make sure the source isn't ruining my experience, which doesn't cost me anything. audiophiles would tell me i am ruining it because i'm using mp3 period, but that's the difference between them and me.
and you are ignorant, just as the OP is. that's all you had to say. 🙂
The argument wasn't whether it's worth it, but whether there is a difference - which of course there is. Personally rip my CDs to 192bit ogg, good enough compromise for my budget for speakers/phones &amp; storage. A select few favorites go into flac.
There's a difference between Enjoy and Prefer.
"I enjoy B cup, but I prefer C."
- M4H
No doubt. I prefer all my audio to be encoded in at least 192K, VBR if possible, but that doesn't mean I can't enjoy the countless hard to find mp3s I've found in 128K based solely on the fact that they're lower quality than what I like.
No, I'm not ignorant. I call it like I see it. If you can't enjoy a 128k mp3 based solely on the fact that its encoded at a lower bit-rate than you'd like, then you're too busy stroking your audiophile ego to just listen to the music.
The differences between a 128K mp3s and CD audio aren't large enough that they should ruin the music for you. If they do, there's something wrong with YOU, not the person who can ignore the differences for the sake of enjoyment.
I seriously think all audiophiles have a mild case of OCD.
