Hi All,
Couldnt get on my other computer and forgot my password, so had to create a new username, usually go by KingT but anyways
I was using my computer fine this morning, save for the blue screen of death, everything was fine... I logged off, shut my computer down and went to bed...
I got up and turn my computer on, The lights inside light up, the fans start spinning, however I get no beeps, I get no video, I cant open my CD/DVD drives, I cant push the reset switch and power switch, I have to manually shut it down by pulling the plug or hit the switch in the back of the power supply..
It wont turn off by the switches in the front of the pc, the motherboard has a light that turns green, the fans go and the lights work, but everything else doesnt.. I opened the case, I took out the video card, unplugged the hard drives, took the bio's battery out, took the ram out and reset it back in...
Put everything and nothing, how can it die in a matter of hours? is it the motherboard? powersupply? I dont know, its got me stumped and im usually good with things like this, was hoping someone out there could help me...
Thanks
-Scott Rose
Thanks
-Scott Rose
